Blower Motor Resistor - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 02-09-2009, 03:40 PM Thread Starter
I just changed mine for the second time and it only lasted 2 days (again)! Anyone know what might be causing them to go bad so fast? I even used die electric grease on this one.
Oh it's on the 99 350 Diesel no A/C fleet model
post #2 of 8 (permalink) Old 02-10-2009, 02:31 PM
high resistance in blowermotor?
post #3 of 8 (permalink) Old 02-10-2009, 03:11 PM Thread Starter
What would cause that?
I am thinking that this one is too much for me and needs to go into the dealer. I would rather fix it myself but I don't have the know how to chase down electrical gremlins.
post #4 of 8 (permalink) Old 02-12-2009, 08:18 PM
the high resistance is a good guess. the only other real option is a screwy switch.
oh, and i know whenever i do ford truck resistors at the shop i end up changing the pigtail too. it's very common that the old one bakes onto the old resistor. if it doesn't snap the locking tabs when you remove it then often there's some burning or corrosion in the connections. that could give some extra risistance right there too, and we all know that unintentional resistance = extra heat = a messed up circuit. whenever i dignose a resistor for these things i order the pigtail automatically : )
gooooooood luck!
Varsity Tyler is offline
post #5 of 8 (permalink) Old 02-13-2009, 05:56 PM Thread Starter
Thanks for the info.
post #6 of 8 (permalink) Old 02-13-2009, 07:55 PM
tohi2care's Avatar
Try lubing it up with silcone spray.
tohi2care is offline
post #7 of 8 (permalink) Old 02-13-2009, 09:57 PM
Stainless's Avatar
Usually when we have vehicle come in with this concern we change the blower motor and resistor I have tryed only a resistor and eventually they come back, do both it will save ya in the long run, and if the wiring shows any signs of meltage change that too!
Stainless is offline
post #8 of 8 (permalink) Old 02-17-2009, 03:34 PM Thread Starter
The wiring is good but the plugs clips have broken off but the plug is not coming out. I'll do the motor/switch and resistor when i get the time/energy again, thanks everyone for your input.
Ford Motor Co. is slashing its stake in Japan's Mazda Motor Corp. fordtough.ca Truck/SUV Talk 5 11-23-2008 10:03 PM
ROUSH KILLS MOTOR The_harleyryder F-150 2004 to 2008 Forum 11 06-01-2008 10:36 PM
Just got it 2001 lightning with 2003 motor 40km on motor Buzzy SVT Lightning 16 04-27-2008 08:02 PM
