'02 f350 wipers and washer no worky - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 18 (permalink) Old 04-13-2009, 03:52 PM Thread Starter
got in truck this morning. wipers and window washer are not working. have checked fuses (30A and 15A) and still not working. next thought is the switch on the turn signal arm. what do you think? common problem?
Loadedagain is offline
post #2 of 18 (permalink) Old 04-13-2009, 05:41 PM
BMac's Avatar
if the fuses are good...check with known good ones before ruling that out, then the multi function switch probably needs to be replaced
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #3 of 18 (permalink) Old 04-13-2009, 09:18 PM Thread Starter
when you say multifunction switch you mean the turn signal arm assembly?
post #4 of 18 (permalink) Old 04-13-2009, 11:28 PM
Multifunction swicth
post #5 of 18 (permalink) Old 04-14-2009, 09:45 AM Thread Starter
damn... i hate taking my steering column apart!
post #6 of 18 (permalink) Old 04-14-2009, 03:17 PM
these trucks were known for the pins breaking out of the multifunction switch connectors,and shorting in the connector also,just remove the lower column cover to inspect.
post #7 of 18 (permalink) Old 04-14-2009, 03:59 PM Thread Starter
this is not looking good so far... it's not the multifunction switch. i grabbed one from a friend at the dealer to try. piece of cake to get at, but it's not the issue.
1) not the fuses (30A or 15A)
2) not multi function switch
is there some sort of relay or controller? i assume the wipers and washer are on the same circuit so maybe there is a control relay shot?? what else?
post #8 of 18 (permalink) Old 04-14-2009, 05:25 PM
magnumpeei's Avatar
did you check the wiring harness for the wiper motor? any loose connections or frayed wires?
magnumpeei is offline
post #9 of 18 (permalink) Old 04-14-2009, 05:58 PM Thread Starter
i did give it a once over, but if it were only the wiper motor wiring i would still have the washer, no?
post #10 of 18 (permalink) Old 04-14-2009, 11:02 PM
BMac's Avatar
wiper motors have been known to go out....but the washer not working is throwing me off, get your buddy at ford to photocopy the wiring schematics for the system and go over them, might give you a few more things to look at
BMac is offline
Opinions wanted for Wipers Matty Ranger Forum 19 01-19-2009 09:29 AM
washer sprayer?? heavyhitter F-150 2004 to 2008 Forum 2 12-06-2008 04:02 PM
New FX6 F350 built Blackstock Super Duty Forum 14 02-10-2008 09:12 AM
New Blue FX6 F350 Blackstock Photo and Video Gallery - Members Rides 7 01-04-2008 11:01 AM
