About lifting the F250 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 16 (permalink) Old 04-15-2009, 05:09 PM Thread Starter
Hi Guys,
i have a question. Is it a better ride when the truck is lifted, worst or no change at all?
And since i'm looking for a F250 2008 with a long box (if it makes a difference??) what tires should i put under and what brand and since i'm in Montreal, who can do the LIFT job here? I dont want a BIG LIFT about 4" is more than enough for me but i kind of like the big tires etc.
William!
will99 is offline
post #2 of 16 (permalink) Old 04-15-2009, 05:21 PM
there just was a thread on this on ford truck world
http://fordtruckworld.tenmagazines.c...st_picksplease
most guys would run a 35x12.5 with that much lift..maybe a 36
this thread will give you some ideas as well
http://fordtruckworld.tenmagazines.c...s=will_36s_fit
Duty calls is offline
post #3 of 16 (permalink) Old 04-15-2009, 07:59 PM
magnumpeei's Avatar
everybody's truck is different when it's lifted. For the most part though, you won't really notice a difference. a good quality lift kit will be a little smoother with the stock tires, but then it gets balanced out by the larger knobby tires, which are always stiffer. the only big difference you'll find is how big your smile is when you drive around
magnumpeei is offline
post #4 of 16 (permalink) Old 04-15-2009, 08:27 PM
BMac's Avatar
First off, figure out what size tires you want to run, then look for a lift that will clear, on the new 08's, there are guys running 37's with a 2.5" readylift
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #5 of 16 (permalink) Old 04-15-2009, 08:37 PM Thread Starter
how much it cost?
How much will it cost (in average) in Canada (around Montreal area) a lift for a truck? Let say 3" or 4"?
thanks
William!
will99 is offline
post #6 of 16 (permalink) Old 04-15-2009, 08:41 PM Thread Starter
well...
Thanks "Duty Calls" but now seeing actually what a 4" lift looks like, i prefer less than that cause i think 4" is too high...
William!
will99 is offline
post #7 of 16 (permalink) Old 04-16-2009, 03:39 PM
William!
make sure you know what you want..because a 4" lift may turn in to regret when you want a 6" 5 months later.....i am experiencing that right now
post #8 of 16 (permalink) Old 04-16-2009, 04:56 PM Thread Starter
About the warranty on the truck?
Hi guys,
is there any problems with FORD's warranty once the truck is lifted? Will they refuse to do anything on it?
thanks
William!
will99 is offline
post #9 of 16 (permalink) Old 04-16-2009, 09:02 PM
BMac's Avatar
as long as its a properly installed kit it won't affect warranty at all
BMac is offline
post #10 of 16 (permalink) Old 04-16-2009, 11:33 PM
why do you want to lift it,for looks or offroad ability?
NEED HELP: 1990 F250 4x4 Henry Ford F-150 Pre-1997 Forum 2 03-09-2010 10:29 PM
Lifting the front end Seb_L Ranger Forum 6 01-22-2009 01:02 AM
Lifting plans for the 08 Ranger FX4 Seb_L Ranger Forum 52 12-30-2008 03:58 PM
F250 Burnout Bush_aholic Super Duty Forum 0 09-27-2008 12:37 AM
Lifting a F-350 osr1 F-150 Pre-1997 Forum 6 04-29-2008 06:53 AM
