NEED HELP: trailer towing? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 05-05-2009, 06:13 PM Thread Starter
trailer towing?
Hi there, i have a 05 F-250 and every time i hook up to any trailer
I keep getting a "check trailer" message in the dash. I have a horse trailer and a dump trailer and a regular utility trailer. All the wiring and lighting and brakes are perfect on all the trailers are good. Both the seven pin and four pin connectors on the back of the truck check out good as well. Any ideas how to cure this annoying problem?? Or what I also need to look at?
rob
indyca is offline
post #2 of 2 (permalink) Old 05-09-2009, 01:28 PM
if all your lights are working, it's likely an issue with the electric brake circuit its the heavy (10ga i think) blue wire on the bargman plug. i would start by tracing that one.
NEED HELP: Towing question painterman F-150 2004 to 2008 Forum 4 05-08-2009 01:51 PM
Towing cnelson09 F-150 2004 to 2008 Forum 1 05-03-2009 10:49 PM
Exhaust for towing? Silver FX4 Intake, Exhaust 6 01-30-2009 12:21 AM
Towing and overdrive fordtough.ca Wheels and Tires 11 06-06-2008 09:09 PM
Did some towing today. Smokefan Wheels and Tires 5 04-01-2007 11:13 AM
