2002 trans type and oil question - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 08-01-2009, 09:14 PM Thread Starter
i have a 2002 f350 7.3 and am about to change the trans oil. i have been told it is a 4r100, but how can i tell for sure? what type of oil should i be using?... mercon or mercon v? ... and does the truck have a converter drain plug?
thanks in advance.
Loadedagain is offline
post #2 of 3 (permalink) Old 08-01-2009, 09:42 PM
BMac's Avatar
it is forsure a 4r100...mercon 5 is what ford is saying to now use I believe, and no drain plug
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #3 of 3 (permalink) Old 08-01-2009, 11:05 PM
You can easily tell a 4R100/ E40D transmission by the word "METRIC" stamped on the bottom of the pan and on the factory door jamb decal under "trans" it will show a letter E there, also,, I cant remember the year that ford stopped putting the drain plug's in the torque converters
Troyer Trans Cooler 06KingRanch Driveline and Transmission 4 06-15-2009 11:32 AM
NEED HELP: Trans crossmember rickwest Driveline and Transmission 2 11-15-2008 04:41 PM
NEED HELP: LOUD vibration type noise RichmondRanger Ranger Forum 6 10-11-2008 09:52 AM
