Marker Light - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 10-13-2009, 05:50 PM Thread Starter
Jerf's Avatar
Marker Light
The marker light on the drivers side mirror of my 08 went out, anyone know how to get the cover off so I can replace the bulb?
Jerf is offline
post #2 of 5 (permalink) Old 10-13-2009, 09:24 PM
there is a small clip on the inside behind the mirror
giver73 is offline
post #3 of 5 (permalink) Old 10-13-2009, 09:45 PM Thread Starter
Jerf's Avatar
I can just reach a tool in past the mirror to release the clip then?
Jerf is offline
post #4 of 5 (permalink) Old 10-13-2009, 11:47 PM
From Recon's website:
To remove your factory turn signal lens you will need to locate the release clip behind the larger,
top mirror of your 2008-2010 Ford Superduty. The clip is physically behind the mirror on the
horizontal edge, just adjacent to the lens.
1. Push the top, inside of the mirror so that there is a large gap by the bottom, outside
edge.
2. You should see the release clip now and you simply need to depress it using a flat
head screwdriver. This will release the light from the mirror.
3. Remove the bulb sockets from the factory lens and then remove the bulbs from the
sockets.
4. Insert our plugs into the vacant sockets and snap your new RECON LED mirror lights
back into the mirror.
5. Test the running lights and the turn signals to ensure the plug is inserted correctly
before snapping the RECON lens onto the housing.
6. You will need to find a place to accommodate the wire inside the housing before you
snap the lens on.
LOOSEWHEEL is offline
post #5 of 5 (permalink) Old 10-14-2009, 01:02 AM Thread Starter
Jerf's Avatar
Thanks that's perfect, now it wont look lopsided at night.
Jerf is offline
abs light albertaboy Sticky Tech/How to Section 3 04-09-2016 02:22 PM
Better light for pics v8ranger Ranger Forum 1 12-31-2008 02:20 AM
Rear light bar fordtough.ca Lighting 17 12-22-2007 12:47 AM
engine light on...help!! lightning25 Gas Engines 8 10-18-2007 10:21 PM
