Bad hubs??? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 11-25-2009, 06:33 PM Thread Starter
Bad hubs???
Hello,i have a 2010 f-350 dually with manual locking hubs.I left hubs locked in the other day and drove a hundered miles or so .To day i hear a noise coming from the hub area that sounds like ball bearings loose in a hub cap.Leaving them locked in 2wd for this many miles would wreck them?I forgot to un lock them before i left my house.Would waranty cover this?Or should i just go bye some warn hubs? Thank`s
bigdaddy is offline
post #2 of 8 (permalink) Old 11-25-2009, 06:48 PM
I'd take it back to Ford. You should be able to drive further than that without any damage, as long as you didn't have the transfer case locked in four wheel drive.
post #3 of 8 (permalink) Old 11-25-2009, 07:34 PM
BMac's Avatar
I've kept manual hubs locked for an entire winter and never had problems, take it in for some warranty work
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #4 of 8 (permalink) Old 11-26-2009, 09:13 AM
As far as going to Warn hubs, if you have ESOF, you will loose this feature if you switch to them. Leaving hubs locked shoudl do no short term damage other than speeding up the wear process on front tires, joints, etc. And it would lower your fuel mileage. If the Tcase was staying locked in, you would know it on dry pavement, the truck would be almost undrivable. I seldom even use 4x4 when in town unless the roads are really bad.
post #5 of 8 (permalink) Old 11-26-2009, 07:36 PM Thread Starter
Hey,took the truck out today cold,no noise.Drove 15km`s and warmmed up the bearings and the noise is back.Hubs still seem to work fine.I locked and unlocked in and out of 4x4 hi and lo and back to 2wd ,no problem.May be its something else.Maybe wheel bearing?
bigdaddy is offline
post #6 of 8 (permalink) Old 11-26-2009, 08:35 PM
Could be a bearing or something floating around in the bearing housing. Did you check to see if there is any rocks stuck in the brake rotor? Either way, It should definitely be a warranty job. That's a brand new truck.
post #7 of 8 (permalink) Old 12-29-2009, 11:43 AM
Crazy_Canuck's Avatar
x2 on that driving thing. i sometimes leave my hubs locked in for weeks and thousands of km's, winter roads can be slippery,then dry,then sli....,i have manual hubs but hubs locked in should not cause any issues.
2011 F350 Dually PSD CC Lariat ultimate still stock
y2k x cab 4x4, with a few extras. broke Feb 2011 collision
Crazy_Canuck is offline
post #8 of 8 (permalink) Old 12-30-2009, 01:39 PM
If you heard the noise and then it was gone, could have been something as simple as dirt, stones, etc. in the wheel clinking around!
blackacres is offline
Locking hubs Snowdoogie F-150 2004 to 2008 Forum 9 12-06-2009 01:27 PM
Weird Noise From Front Hubs Rick762 Wheels and Tires 3 10-22-2009 09:03 PM
Anyone else ever used PartsMaster Wheel hubs? sledmanjones F-150 1997 to 2003 /04 Heritage Forum 5 03-01-2009 12:48 PM
AVM manual hubs rangerT Ranger Forum 3 10-16-2008 01:11 PM
one bad bronco v8ranger Photo and Video Gallery - Members Rides 6 02-08-2008 12:49 PM
