NEED HELP: Headlight bulbs - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 11-29-2009, 08:47 AM Thread Starter
Headlight bulbs
I finally picked up some new headlight bulbs for my 06 F350. What's the best way to get at the bulbs? The book says to remove the assembly from the front by removing four screws, but it needs some tiny little nut driver I don't have. Is it easier to get to frrom the back? Do I need to remove the power steering resovoir?
thanks for any help.
mataspr is offline
post #2 of 15 (permalink) Old 11-29-2009, 11:18 AM
BMac's Avatar
easiest is to remove the 4 screws, two on top and two on the bottom front
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #3 of 15 (permalink) Old 11-29-2009, 11:20 AM Thread Starter
Thanks for the reply. What is the nut driver I need? is it 6mm? It sure is small.
mataspr is offline
post #4 of 15 (permalink) Old 11-30-2009, 12:30 AM
it should be 5.5mm
post #5 of 15 (permalink) Old 11-30-2009, 10:41 AM Thread Starter
Originally Posted by shelbyx1 View Post
it should be 5.5mm
Do you know where I can find a nut driver that small? I've tried Cdn Tire and Princess Auto.
thanks
mataspr is offline
post #6 of 15 (permalink) Old 11-30-2009, 01:24 PM
ml878us's Avatar
1/4" drive 5.5mm socket is pretty much a standard in any el-cheapo (jobmate ect) set. It'll come with a driver handle in 1/4" drive, and a whole handfull of ridiculously small sockets.
ml878us is offline
post #7 of 15 (permalink) Old 12-30-2009, 12:25 PM
I just changed my bulbs, I seem to recall I used a 7/32" socket, probably close to 5.5 mm.
I used a 1/4" socket handle/driver, along with a 1/4" x 6" extension to reach the bottom screws.
After removing the four screws from the headlight housing, I wrestled a bit with the headlight assembly, as it wouldn't clear the grill.
So, I ended up removing the screws along the top of the grill, then I could lean it out a bit, then the headlights assy's were much easier to get in/out.
Also, to get the two screws back into the bottom holes, I used a small extenable magnet to hold the screws in the socket, so they wouldn't drop out of the socket!
I went with Piaa, super white, H13's, now I kind of wish I'd bought an HID kit!!!!
blackacres is offline
post #8 of 15 (permalink) Old 07-18-2010, 10:43 PM
trucker101's Avatar
{Cut & Snip}
I'm kind of new to all this, Why, do they draw too much power?
trucker101 is offline
post #9 of 15 (permalink) Old 11-24-2010, 10:00 AM
I also was thinking of upgrading head lights. I heard that people recommend PIAA but is there any others that are as good but cheaper ( Phillips, GE etc)
zedeng is offline
post #10 of 15 (permalink) Old 11-25-2010, 12:04 AM
i've had better luck with the piaa bulbs(knock on wood)they seem to last longer.
signal bulbs shelbyx1 Truck/SUV Talk 18 01-20-2009 12:38 PM
Burnt out headlight TRUKNUT Lighting 24 05-31-2008 10:38 AM
Xenon bulbs Kirkfry Ranger Forum 12 04-25-2008 10:47 PM
Chrome Bulbs UpGrade white4by4 Lighting 23 02-17-2008 10:09 AM
Are you looking for colored light bulbs fordtough.ca Lighting 2 12-20-2007 10:17 PM
