Heater fan - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 01-03-2010, 12:25 AM Thread Starter
Heater fan
Heater fan switch works on low and high no inbetween settings this a relay or fuse problem or ?
also the switch for hot or colder temps when moved up a bit from thehottest setting to cooler temp setting its a huge temp change just luke warm air unless all the way on hot then you could cook a turkey in here lol this just a diesel thing ? or ?
thanks
post #2 of 7 (permalink) Old 01-03-2010, 06:02 PM
I don;t know what your issue is with the fan speed unless mabe the switch has started to come apart at the back. They are 2 pieces that snap together.
I do know that on my 2007, the heater is not very linear on the temp control even though my past SD's very very accurate and yes, a small movement off of the hottest position makes a huge difference in temp.
post #3 of 7 (permalink) Old 01-03-2010, 08:31 PM
I forget the official term for it, but if you look under the hood and go to the heater box, you'll see the blower motor and there is also a "thermal coil pack" that is inside the housing of the heater box. Just follow the wires to it (usually 3 or 4 that go into a plug) and unplug it, then take the coil out (usually 1 or 2 screws). If you look closely at the unit you'll see a few coils of wire that have different thicknesses. Each one of those coils is for each speed of the fan, and if one of those coils has a break in it, that circuit will open and fan will stop for that particular speed. Check this first.
post #4 of 7 (permalink) Old 01-03-2010, 09:19 PM Thread Starter
Thanks for the info i will check it out
post #5 of 7 (permalink) Old 01-03-2010, 09:38 PM
Blower motor resistor
post #6 of 7 (permalink) Old 01-03-2010, 10:51 PM
do you have manuel switches or auto?if you have manuel switches could be the blend door motor or door itself,just lower the glove box and on top of the heater plenum is an actuator,while moving switch hot/cold watch to see if motor moves smooth.
post #7 of 7 (permalink) Old 01-03-2010, 11:01 PM Thread Starter
thanks for all the info
i have the manual 3 sep switches for the blower/heat,cool/settings
Heater Fan Speed terrier2006 F-150 1997 to 2003 /04 Heritage Forum 1 08-28-2009 02:38 PM
BLOCK HEATER MississaugaRanger Ranger Forum 30 03-06-2009 11:28 PM
NEED HELP: fan cowling albertaboy Gas Engines 4 02-08-2009 11:16 AM
Heater Help BigDawg99 Interior 8 11-08-2008 07:17 AM
electric fan Jensen Gas Engines 3 07-18-2008 04:56 PM
