HELP fuel line connector removal - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 02-01-2010, 10:19 PM Thread Starter
help, anyone, im installing a larger titan fuel tank on my 06 6litre diesel and i have the tank out but can t get the fuel lines to come off the sending unit - i went and picked up the round plastic line disconnect,, but dont think its rite.
i understand that there are different types of fuel line connectors. the one i have is like a square plastic and has to holes in the bottom and a white clip recessed in the one side...
is there a way to de pressurize the lines? could that be my problem? it looks like i need a u shaped clip tool?
i have the old tank outside the garage and the new tank in front of the truck on the floor..... i really need to get the lines off so i can get the truck back to gether....anybody in bonnyville want to make some $$ .....any info would be greatly appreciated....
terry
ttpower1 is offline
post #2 of 6 (permalink) Old 02-02-2010, 12:11 AM
on the fuel rail under the hood you'll see what looks like the top of a tire valve stem. Push to depressurize the fuel line
post #3 of 6 (permalink) Old 02-02-2010, 01:25 AM
what I do when depressurizing the fuel rail is hold a rag over it shrader valve so fuel wont spray all over the place, I also use a small flat blade screwdriver to push the valve in to depressurize it
post #4 of 6 (permalink) Old 02-02-2010, 03:13 AM
thanks for explaining it better Dave. I've done it so many times I sometimes forget to explain things completely!
post #5 of 6 (permalink) Old 02-02-2010, 03:22 PM
as for the clips you push the white tab into the connector(you may have to blow out the inside of the connector as they fill up with dirt)push the connector towards the pump then push in tab and remove line,when you install the tank will have to extend the fill tube.if you need any more assistance feel free to pm me.
post #6 of 6 (permalink) Old 02-03-2010, 11:42 PM Thread Starter
thanks guys got it
ttpower1 is offline
Panel Removal macs07 F-150 2004 to 2008 Forum 2 01-20-2010 07:45 PM
fuel line magnets macs07 F-150 2004 to 2008 Forum 1 04-26-2009 12:10 PM
Trailer connector help Swoosh66 Audio and Electronics 9 12-17-2008 11:03 AM
Dash Removal and I-pod connector canadiantowman Audio and Electronics 3 08-29-2008 08:47 PM
Headlight Removal??? white4by4 F-150 2004 to 2008 Forum 5 02-05-2008 11:40 PM
