6.0L head studs - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 02-27-2010, 04:57 PM Thread Starter
Axehandler's Avatar
6.0L head studs
O.K. Betsie is 7 years old with 340K km and still runs like a top. I am the 2nd owner how can i tell if the head studs/Gasket have been done before I put some money into more boost?
I'm itching to get some more juice outa her.
2003 F350 Super Cab XLT 6.0L
4.5 lift
35" tires
Her name is "Betsie"
Axehandler is offline
post #2 of 5 (permalink) Old 02-27-2010, 09:17 PM
Stock, it's head bolts, not studs so even if you can confirm gaskets have been done, you need to confirm that the bolts were replaced with the ARP studs because just replacing bolts will not put the 6.0L up the challenge of being modified. If your ready to play, give 'er, but be ready to pay, things may start happening while your having fun that could cost some coin.
Keep us informed of what you do, it will be interesting!
post #3 of 5 (permalink) Old 02-27-2010, 09:52 PM Thread Starter
Axehandler's Avatar
Stock is bolts then and Studs is after market.
4.5 lift
35" tires
post #4 of 5 (permalink) Old 02-28-2010, 07:26 AM
zip
zip's Avatar
I guess the only way would be to pop a valve cover off and take a look see.
Chris
75 F150, 79 Bronco
zip is offline
post #5 of 5 (permalink) Old 02-28-2010, 07:32 AM
Yes
Here is a bit of info:
http://www.dieselpowermag.com/tech/0.../photo_04.html
4.6 Cylinder head Fordwheeler Gas Engines 0 11-06-2009 08:24 PM
manifold studs LayinHp F-150 1997 to 2003 /04 Heritage Forum 0 02-22-2009 11:22 AM
Head Gasket on an 07?? 07rangersport Ranger Forum 15 02-02-2009 12:12 AM
Ranger head units.... CanadianRanger Ranger Forum 13 01-03-2009 07:13 PM
