Wheel Bearing - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 11-13-2010, 10:13 AM Thread Starter
Wheel Bearing
Are Ford replacement parts good quality ? (no chinese replacement junk) Ive used there stuff before on the explorer but didnt have it long after i sold it i think the brand was Temkin ? would the same brand be used for the superdutys ?
Have a drivers front on the way out looking for decent prices.
Whats involved to change them ? its for an 2007 F350 4x4 heard different stories.
post #2 of 11 (permalink) Old 11-13-2010, 12:00 PM
I've replaced a few and I use bearing units from Kaman Bearing, which is a local industrial bearing outfit. They are quality pieces with SKF bearings. Not bad prices compared to factory stuff. Bea ready to buy all the seals which are not cheap...around a 100 bucks a side and you'll need a special tool to install the main seal. I borrowed the tool from a friend who works at the dealership. When you do this job, seriously consider replacing the axle u-joints with greaseable u-joints. This will save you from buying seals twice as the seals are a one time deal. Some places have a seal "kit" like powerstrokeshop.com. I used dealer seals as I needed them right away.
post #3 of 11 (permalink) Old 11-13-2010, 06:39 PM
Am I missing something here? The bearings on the 4x's are part of the whole hub assembly. Your looking at about 475 bucks from Ford and get this- about a 1000 bucks from Napa! They come complete with a new ABS wheel sensor with is worth about $100 alone.
post #4 of 11 (permalink) Old 11-14-2010, 10:03 AM Thread Starter
i thought they were one unit aswell.... ?
fordsforever were they different for different years ?
$475 ? wow figured $200-$300 but it is for a heavy duty set up, guess im going to need to call in a favour or two get better priceing
post #5 of 11 (permalink) Old 11-14-2010, 10:29 AM Thread Starter
http://www.dynatrac.com/products_freespin_ford.html
would be nice to upgrade to this set up and get rid of the sealed unit crap
post #6 of 11 (permalink) Old 11-14-2010, 12:56 PM
atk
atk's Avatar
Send a message via MSN to atk
that kit is not cheap. been looking at them as well....
for 200-300 you will end up with a cheap replacement, that probaly won`t last....
also as stated before, do the universal(greaseable) while you are there, it will save money down the road....a tool can be made to install seal, unless you can borrow one....
2004 FORD F-250 XLT 4x4 C/C S/B....
Sct-Livewire with custom tunes, guages, 4" exhaust,coolant filter....soon to be tuned by PHP....
atk is offline
post #7 of 11 (permalink) Old 11-14-2010, 01:33 PM
I picked up some parts from rockauto.com
found a 5% discount coupon with quick search on google.ca
prices were cheaper then any local places here.. and you pay taxes which is prepaying brokerage.
worked out I paid about half. then if i were to buy local here.
post #8 of 11 (permalink) Old 11-14-2010, 03:27 PM
Forgot to say, not only should you think about changing the u-joints, but ball joints too. Then you basically have a brand new frontend that you can grease and make last much longer than the factory stuff.
post #9 of 11 (permalink) Old 11-14-2010, 04:13 PM
atk
atk's Avatar
good point.... have had good luck with MOOG in the Superduty`s....
atk is offline
post #10 of 11 (permalink) Old 11-14-2010, 04:58 PM Thread Starter
balljoints have all been done for the saftey just before i bought it, on the drivers side it already has a greasable u-joint (passengerside doesnt...yet) it has had some work done but the wheel bearings been makeing the dreaded noise and it was hard to hear over the exhaust but now its noticable
NEED HELP: 2000 Ford Ranger-Wheel Bearing... mustangracer5_0 Ranger Forum 2 11-11-2009 12:27 AM
new truck/bad bearing blk&wht Ranger Forum 7 10-31-2009 12:19 AM
Wheel Bearing maybe murray99 F-150 2004 to 2008 Forum 12 06-04-2009 12:18 AM
Driver's side wheel bearing MRGADGET Wheels and Tires 14 04-04-2008 05:28 AM
wheel bearing failure canadian redneck Super Duty Forum 6 03-06-2008 12:59 AM
