Better front axles for turning in 4X4 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 11-22-2010, 11:02 AM Thread Starter
Smile Better front axles for turning in 4X4
Has anyone replaced the front axles ( u joints and shaft ) to improve the turning radius of the truck when the truck is in 4 wheel drive? I was thinking that there might be a heavy duty CV axle instead of the U joint axle after market kit available.
Cheers
zedeng is offline
post #2 of 4 (permalink) Old 11-22-2010, 12:33 PM
I doubt a CV joint would fit. You may find some after market shafts that allow a tighter turn, but I'm sure the cost would hinder most from even thinking about it. Maybe you'll invent something and make millions?
post #3 of 4 (permalink) Old 11-22-2010, 06:42 PM Thread Starter
Are " high angle " axle joints common for a stock truck ?
zedeng is offline
post #4 of 4 (permalink) Old 11-24-2010, 03:50 AM
If you want to turn tighter, put in a rear steer axle
Duty calls is offline
NEED HELP: Turning off DRL Kimmer F-150 2009 to 2014 Forum 3 08-24-2010 06:31 PM
NEED HELP: Truck makes some weird stuff when turning jayman3 Super Duty Forum 9 02-19-2009 10:49 AM
NEED HELP: 1997 ranger 4x4 front hub Nanaimowill Ranger Forum 2 12-25-2008 01:08 PM
AXLES Beezer F-150 Pre-1997 Forum 5 11-16-2007 02:26 PM
