Blend Door - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 11-28-2010, 10:05 PM Thread Starter
Blend Door
Blend door Resistor modual... on a 2007 F350 is it behind the glovebox area ? no manual just going by a few posts ive read on a google search but they were pre 2005 model years...
all i still have is low and high speeds.... actually forgot all about it untill it started to get cold out
post #2 of 5 (permalink) Old 11-29-2010, 01:22 AM
Blend door resistor? I think you're talking about the resistors that control the fan speed. Got nuttin' to do with the blend door (damper).
Not sure about the F350, but in almost every vehicle I've seen the resistors are mounted inside the air intake plenum on the engine compartment side of the firewall. To get at them, you usually take off the blower motor on the firewall, and they're inside the plenum. I think they mount them there because the blower fan pulls in cold outside air and it helps keep the resistors cool.
Somtimes they are seperately mounted on the firewall, but pointing into the plenum. Then you don't need to pull the blower motor.
Just look for something that looks like this:
Or maybe like this ...
post #3 of 5 (permalink) Old 11-29-2010, 02:56 PM
the blower resister is underhood pass side beside blower motor.
post #4 of 5 (permalink) Old 11-29-2010, 06:11 PM Thread Starter
Thanks !
pain in the ass with onl low and high speeds
post #5 of 5 (permalink) Old 12-20-2010, 08:58 AM Thread Starter
well changed it... and..... now instead of low and high i have low/2nd speed up and high and no 3rd and the high doesnt blow as strong as it did with the old part...... ? so could this be another problem ? or just a bad new modual ?
Blend Door Actuator for 08 ranger westcoastranger Ranger Forum 6 11-29-2010 05:35 AM
Blend door problems mrite F-150 1997 to 2003 /04 Heritage Forum 2 06-17-2010 10:24 AM
NEED HELP: DOOR HINGES big-papa F-150 Pre-1997 Forum 3 06-01-2010 01:38 AM
Door Hinges JimyB Sticky Tech/How to Section 14 04-08-2010 11:12 PM
Fuel door funhog F-150 2004 to 2008 Forum 4 05-17-2009 03:54 PM
