NEED HELP: 2007 f-250 No Heat issue - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 01-28-2011, 08:10 PM Thread Starter
Hi all, new to forum and looking for some help with no heat on a 2007 F-250 King Ranch 6.0L.
The issue started before christmas with intermittent no heat in the cab, only at low idle parked. Replaced the thermostat, topped up the coolant and removed the coolant shut off valve for a/c, but it seems almost like i have a blend door issue. Issue only was happening at idle at first but now it is happening driving as well. Air temp warms up to normal, then will start to blow cold air (almost like turning a/c on or turning temp control to cold) but will then go back to hot air. I have the auto temp system, vacuum does not seem to the problem...with no vacuum the system defults to defrost and 4x4 does not engage...this does not happen.
any trouble shooting help would be appriciated
thanks in advance
Al
smbinc is offline
post #2 of 8 (permalink) Old 01-29-2011, 09:50 AM
mechanix61's Avatar
Keep an eye on your coolant bottle, make sure you are not puking out any coolant.be sure not too over fill, then post results
mechanix61 is offline
post #3 of 8 (permalink) Old 01-29-2011, 11:14 AM Thread Starter
coolant bottle remains full. not leaking out.
smbinc is offline
post #4 of 8 (permalink) Old 01-31-2011, 03:31 PM
when up to operating temp both hoses should be hot,if 1 hot/other cool could have plugged core,if both cool could have blocked orifice in heater hose or stuck t/stat.
post #5 of 8 (permalink) Old 01-31-2011, 11:50 PM
1white08fx2's Avatar
/\ Agreed/\
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #6 of 8 (permalink) Old 08-13-2011, 05:05 PM Thread Starter
Hi all...update time. Heater core plugged...tryed to back flush with hot water and soap,then new coolant. still same. ordered a new heater core
smbinc is offline
post #7 of 8 (permalink) Old 08-13-2011, 11:46 PM
Might be time to look into flushing your cooling system. Common issue with the 6.0 is the sand left in the coolant passages. So a flush and an added filter is a good idea. If your heater core is plugged you may have an issue with the egr or the oil cooler plugging (big bucks). I'll post some good links for you to look at below. I eliminated my egr system already and this winter I'll be replacing my oil cooler with the upgraded one from Ford and I will also be doing the flush and installing a coolant filter as I have puking (coolant) issues. And I suppose I'll replace head gaskets and add the ARP head studs.
Man, now that I re-read this, it sounds like a lot. But it's still worth it as I plan on keeping this truck a loooong time!
Good luck and be sure to keep us posted.
Links to check out:
http://www.thedieselstop.com/forums/...-today-283186/
http://home.comcast.net/~lyon.family...ush%20v1-0.pdf
post #8 of 8 (permalink) Old 08-18-2011, 03:56 AM
HTRDDSL's Avatar
A coolant filter is the first Mod I'm gonna add to the 07 I just bought.
HTRDDSL is offline
no heat in my 1998 explorer fordexploder05 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 1 10-18-2010 03:35 PM
No heat Fordwheeler Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 9 09-21-2010 10:02 AM
NEED HELP: looking for an F-250 Lilbigtrk Super Duty Forum 8 10-26-2008 08:19 AM
My new Ford F-250 Squirrel Photo and Video Gallery - Members Rides 10 03-11-2008 08:55 AM
