heat/ac problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 02-23-2011, 02:46 PM Thread Starter
heat/ac problems
hi all, i have a small problem i need your help with. wether on air or heat the selectors in the dash for directing air flow does not work.
all air flow is going to the defrost area only.
any sugestions as to why or how to fix.
my truck is a 06 F250 Harley Davidson Edition with eletric selection for air flow.
thank you in advance
andy
trailing along is offline
post #2 of 11 (permalink) Old 02-23-2011, 02:51 PM
the mode selection is vacc operated,a common thing is under glove box a vacc lead comes apart,also if the front hub-locks don't work check the vacc pump on the rh inner fender.
post #3 of 11 (permalink) Old 02-23-2011, 03:44 PM Thread Starter
hi Shelbyx1, thanx for the reply. i checked the vac hoses behind the glovebox and no sign of any loose or let go. the pump seems to be working also.
when i turn the switch for the 4x4 you can hear it engage and disengage.
i'll have to find a dirt area here somewhere to see if the hubs do lock in.
thank you for the info
andy
post #4 of 11 (permalink) Old 03-06-2011, 10:53 AM
sounds like a blower motor resister is gone,
2005 f250 crew harley
1993 civic [email protected]
www.fukenricen.ca
Fukenricen is offline
post #5 of 11 (permalink) Old 03-08-2011, 11:51 AM
If the vacuum is doing it's thing, wouldn't that mean the door is stuck?
post #6 of 11 (permalink) Old 04-12-2013, 11:12 AM
stormy663's Avatar
I have a 2000 F350 with the same issue. Same fix?
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
stormy663 is offline
post #7 of 11 (permalink) Old 05-06-2013, 11:21 PM
get it scanned, and not by a tuner or a $200 unit from canadian tire. you want to know if there are any Bxxxx codes stored in the HVAC module. that will tell you right away if you are dealing with a controller, circuitry or motor issue or if it's something mechanical with the mode door.
good luck.
Varsity Tyler is offline
post #8 of 11 (permalink) Old 05-08-2013, 01:21 AM
zip
zip's Avatar
Could be a blend door issue.
Chris
75 F150, 79 Bronco
zip is offline
post #9 of 11 (permalink) Old 05-08-2013, 12:45 PM
stormy663's Avatar
On my 2000 F350 it was a simple issue of the vac line being loose. I am also looking to replace or refurb the pump if I can find a cheap one.
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
post #10 of 11 (permalink) Old 05-21-2013, 03:39 PM
YKX
I have the opposite problem, the defrost air is coming throught the vents, seams like the door is stuck to the vent position. I have a '11 sd 6.7. How do i take take the glove box off to look? Thanks
YKX
YKX is offline
NEED HELP: 2007 f-250 No Heat issue smbinc Super Duty Forum 7 08-18-2011 02:56 AM
no heat in my 1998 explorer fordexploder05 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 1 10-18-2010 02:35 PM
No heat Fordwheeler Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 9 09-21-2010 09:02 AM
problems tear u a new 1 FordTough.ca Site Help? 6 11-03-2007 02:18 AM
