NEED HELP: slow coolant leak - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 10-29-2011, 12:06 PM Thread Starter
slow coolant leak
Hey all, I was changing the drag link on my 2000 Excursion PSD the other day and noticed what looked like a leak. On closer examination I saw some greenish drips on the hose under my truck. Anyone have a similar issue? What am I looking at here?
Thanks,
George
oilman is offline
post #2 of 4 (permalink) Old 10-30-2011, 01:33 PM
Loose hose clamp?
post #3 of 4 (permalink) Old 10-30-2011, 09:16 PM
glufactory5.4's Avatar
Either coolant OR a/c system dye, pressure test cooling system or add dye to coolant and check if you can get your hands on a uv light,you can check both
-2003 F-150 5.4 4X2 SHORTBOX STEPSIDE
-HEAVILY MODIFIED
glufactory5.4 is offline
post #4 of 4 (permalink) Old 10-30-2011, 11:37 PM
Originally Posted by b4000 View Post
Loose hose clamp?
recently dropping below freezing at night, check your hose clamps.
very common with coldleaks.
68Mercury250Ranger is offline
NEED HELP: Exhaust Leak-i think? blaster23 F-150 2004 to 2008 Forum 18 06-19-2011 01:38 PM
NEED HELP: Prestone/Coolant Smell? LaredoRV F-150 2004 to 2008 Forum 6 01-03-2011 03:14 PM
Propane Leak? Knightruler Gas Engines 0 08-21-2010 12:08 PM
Slow around here B Rent F-150 Pre-1997 Forum 4 06-08-2010 03:48 PM
Major Coolant Leak...please help. Elgando Super Duty Forum 1 05-23-2008 11:25 AM
