NEED HELP: Shift-Knob Button - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 08-01-2012, 01:07 PM Thread Starter
Shift-Knob Button
Vehicle: 2007 Explorer Sport Trac V8 Limited (no warranty or extended warranty remaining)
Problem: The shift-knob button appears to be loose, or doesn't have the ability to be depressed completely to allow for a smooth shift between gears. It hasn't locked up, but I am very conscious of how much pressure I exert on the button to make sure it shifts.
I have heard there is a TBS solution (doesn't apply to me with no warranty), I have also seen a YouTube video that removes a black piece within the shifter mechanism (when you depress the brakes, its clicks), but I am not sure this is the root cause of the issue.
Anyone experience such problems, and have a DIY solution? or do I have to bring it in to the mechanic?
Thanks.
Strko75 is offline
Is it possible to take the heat temp knob off? Arctic F-150 F-150 2004 to 2008 Forum 5 11-05-2011 04:23 AM
headlight & A/C knob removal? tank_dean F-150 2004 to 2008 Forum 0 09-04-2010 11:32 AM
Start engine button Spinal Interior 37 05-12-2010 09:11 PM
Push Button Start BlairTruck F-150 1997 to 2003 /04 Heritage Forum 9 05-18-2009 05:56 PM
aftermarket automatic shift knob sodapop F-150 2004 to 2008 Forum 0 04-22-2009 01:35 PM
