reverse lights problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-08-2012, 10:26 PM Thread Starter
grinder4.2's Avatar
hey guys i have a problem with my reverse light on a 2000 expedition xlt 5.4L so here's what i have figured out i tested the transmisson switch and there is power coming out of the switch on the pink and black wire which is the reverse switch wire but i dont have any power at my lights so does any one know where the wire runs from the transsmison switch to the taillights
"CANT FORD IT DONT BUY IT"
grinder4.2 is offline
post #2 of 7 (permalink) Old 12-09-2012, 10:25 AM
Fuse?
post #3 of 7 (permalink) Old 12-09-2012, 12:39 PM
Like Travis said, I'd start with the simple stuff first...fuse, bulb, where you got power, where you don't (which you've started already).
Electronic gremlins are fun. Not. Good luck.
post #4 of 7 (permalink) Old 12-09-2012, 10:13 PM
Are both lights out or just one?
post #5 of 7 (permalink) Old 12-10-2012, 03:55 AM Thread Starter
grinder4.2's Avatar
ive checked all fuses i have power leaving the transmission range sensor when in reverse but there is no power at both reverse lights
post #6 of 7 (permalink) Old 12-10-2012, 08:05 AM
It stays near or in the dash until it leaves the remote anti-theft personality module. Then goes through the seatbelt harness, mirrors then off to the back up lights.
post #7 of 7 (permalink) Old 12-10-2012, 02:22 PM Thread Starter
grinder4.2's Avatar
does that run under the door sills plates, in the 2 wire harnesses that are there?
and could i open it up and probe the right wire?
terrible reverse lights Bandit993 F-150 2009 to 2014 Forum 90 01-03-2013 11:42 PM
2010 reverse systems aspinape F-150 2009 to 2014 Forum 1 09-14-2009 01:36 AM
Reverse Sensor going off for nothing RJohn357 F-150 2004 to 2008 Forum 10 01-27-2009 09:31 PM
08 Reverse Camera? 04STXHERITAGE F-150 2004 to 2008 Forum 15 12-22-2008 07:49 PM
Euro Tail Lights Problem mitchbtu Lighting 7 05-27-2008 12:16 PM
