Sluggish starting - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 08-11-2013, 10:13 PM Thread Starter
Sluggish starting
Hey everyone, I noticed my 2000 PSD EX is starting sluggish the last couple of days. Last time it sounded like this one of the batteries was no good, replaced it and everything was fine. that was a couple of years ago. So when I noticed it doing the same, i tested both batteries with a cca tester and the one I replaced 2 yrs ago was good, now it was the other one, so i bought a new battery today cleaned the K&N air filter and it still starts sluggish. The alternator and the starter have been replaced within the last year and half.
Any suggestions?
George
oilman is offline
post #2 of 6 (permalink) Old 08-12-2013, 04:50 PM
Canadian Bacon's Avatar
How's your oil? Synthetic or Conventional? What grade? Any additives? Ever changed injectors? How many KM's?
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #3 of 6 (permalink) Old 08-12-2013, 07:44 PM
Check grounds to the engine block?
post #4 of 6 (permalink) Old 08-12-2013, 08:40 PM
1white08fx2's Avatar
Plus one with the above..... at the same time, wouldn't hurts to test the battery, or altenator too. Doesn't matter if either were replaced within the last year or not. I've seen it where an altenator kept being an issue on a buddy's car once, they were just defective from the supplier. The factory oem one will go on for a long time, but the replacement ones could last a year, or less, or more, same goes for the battery.
Even dirty battery terminals will give you issues. It's good to keep those clean yearly, preferably after winter in the spring.
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #5 of 6 (permalink) Old 08-12-2013, 09:44 PM Thread Starter
It was the starter.
oilman is offline
post #6 of 6 (permalink) Old 08-15-2013, 10:10 PM
Congrats..... Easy fix.
aka 1LOW03GT
Starting the truck hyperhad F-150 2009 to 2014 Forum 3 08-17-2012 10:35 PM
starting issues/ truckguy94 F-150 Pre-1997 Forum 20 05-19-2010 06:32 PM
Starting up Mar Ranger Forum 3 02-28-2010 11:01 AM
starting trouble oilman Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 8 11-23-2008 06:31 PM
