Flashing OD light - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 02-07-2014, 02:17 PM Thread Starter
Flashing OD light
My sister recently bought a 2002 Explorer 4x4 4l v6 The OD light has been flashing on and off a few times. First time was durring a pass on the highway and now its doing it onanother highway drive with no high rpm driving. Gonna run the code reader on it when she gets into town and check the trans fluid. Maybe even do a rad flush as thats what stopped the same issue in a 96 I had. Any other suggestions?
post #2 of 3 (permalink) Old 03-15-2014, 01:27 PM
stormy663's Avatar
Check your speedo sensor. I had the same issue on my 2000 F350. I had no speedo at the same time.
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
stormy663 is offline
post #3 of 3 (permalink) Old 06-08-2014, 10:01 PM
TRNRBILT's Avatar
Old thread but what was the issue with this. My dad just bought an 03 and it has the light flashing all the time but will not go into gear. Was it as easy as doing a trans filter and fluid. Or is it the torque converter lockup solenoid like my scanner thinks.
TRNRBILT is offline
abs light albertaboy Sticky Tech/How to Section 3 04-09-2016 02:22 PM
Turn signals and hazard lights not flashing on my 2010 Ranger? DavidY Ranger Forum 9 04-10-2011 09:51 PM
Flasher not flashing Fordwheeler Exterior 7 11-11-2010 09:09 PM
ABS light swampthing Diesel Trucks 2 09-29-2010 09:52 PM
Airbag light flashing truckguy94 F-150 Pre-1997 Forum 14 03-09-2010 11:25 PM
