Cruise Control 98 Explorer - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 03-13-2014, 08:36 PM Thread Starter
stormy663's Avatar
I can't figure out what is wrong with my CC. It simply does not work. I have checked fuses, connections and can't figure it out. Anyone?
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
stormy663 is offline
post #2 of 7 (permalink) Old 03-13-2014, 11:50 PM
Clock springs, control module, throttle cable, vacuum leak(which maybe your egr problem as well)? Does your speedo work? Need to narrow it down more.
post #3 of 7 (permalink) Old 03-15-2014, 01:24 PM Thread Starter
stormy663's Avatar
My speedo works fine. Everything seems to work. The CC almost seems to be disconnected.
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
post #4 of 7 (permalink) Old 07-16-2014, 03:37 PM Thread Starter
stormy663's Avatar
It is almost like it has been disconnected. The only thing that I haven't done is trace the wires.
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
post #5 of 7 (permalink) Old 07-17-2014, 09:16 AM
And did you check the rest?
post #6 of 7 (permalink) Old 07-17-2014, 08:32 PM Thread Starter
stormy663's Avatar
Throttle cable is good, no vacuum leaks, speedo good, OBDII not showing anything ..
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
post #7 of 7 (permalink) Old 07-18-2014, 10:58 PM
Check the steering wheel buttons and see if they measure the right resistances.
F 150 recall #05 s 28./cruise control GLENN British Columbia 3 11-14-2013 01:19 AM
2004 lariat Cruise control not working darren F-150 2004 to 2008 Forum 4 11-16-2009 12:56 PM
FORD re-issue recall for cruise control f150phule F-150 2004 to 2008 Forum 3 03-11-2008 12:12 AM
