starting trouble - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 11-21-2008, 08:26 PM Thread Starter
Unhappy starting trouble
I had a trouble code come up on my 2000 Excursion7.3L PSD that said P0674- Glow plug # 4 circuit fault.
I decided to change all the plugs, which I did a week ago. I'm still getting the check engine light coming on and the same trouble code, even after clearing the code. I have also had to boost the truck twice in the last week even though I keep it plugged in. It seems to happen when it hasn't been started in a couple of days in the colder damper weather.
could it be the glow plug relay or module? How can I find out?
Any info would be appreciated,
GD
oilman is offline
post #2 of 9 (permalink) Old 11-21-2008, 09:10 PM
BMac's Avatar
plugging it in has nothing to do with your batteries... so your batteries are probably shot, both those should be replaced.
Check your UVCH to make sure all the connections are there and there isn't any chaffing. If all that looks good make sure your GPR is good, can't remember how many volts its suppose to be, i'll see if I can dig around some of my stuff and see
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #3 of 9 (permalink) Old 11-21-2008, 09:13 PM
BMac's Avatar
Found the write up I have for hard starts...here ya go
The first and easiest test is to check the glow plug relay.
1) Let the truck sit overnight in fairly cold temps ( < 45º ) this will require the glow plugs to activate for a good amount of time for the truck to start properly.
2) The test part can be done several ways, first of all if you have a voltmeter, dial it up to the correct setting for 12V systems, ground it to a good ground, and put the + lead on the right/back side of the glow plug relay. With the key off, that terminal should read zero, while the other one (which connects to the battery) should read +- 12V at all times. You want to measure the one with zero voltage.
When the key is turned on, the one that had zero should go up to 12V and stay there for 30sec - 2min. This is feeding the glow plugs 12V to heat them up.
3) Have someone turn the key on for you, or turn it on and get back around to your tester quickly, and see if you have 12V across the relay. If you do, see how long the relay stays activated, if it goes off very quickly it's not allowing the gp's enough time to heat up and the truck is going to start rough. If the relay fails this test, replace it.
2-3a.) Some alternate methods to above, instead of using a voltmeter, jumper across the relay either with a screwdriver (which will cause sparks until you make a good contact) or with a set of jumper cables from the hot + terminal on one of your batteries, to the gp side of the relay. Make the connection for about 45 seconds, then immediately try to start the truck. If it fires up nicely, whereas it was struggling before, the relay is bad.
4) If the relay passes the test, and is good. Or if you replace the relay and still experience hard starts, you will need to move on to testing the glow plugs themselves. This can be done quite non-invasive, only requiring you to pull the valve covers if you find a bad glow plug, to replace it / them.
5) There are also a couple ways to test the glow plugs, you will need either a test light, or a good voltmeter that will read in ohms.
5a) Voltmeter method - Remove the large rectangular plug leading to the valve covers on either side of the engine. This plug powers your glow plugs and injectors. The 2 outside pins are your glow plugs, the 4 inner ones are for the injectors. () () () () () () () () Blue is the Glow Plugs Red is the injectors. Be very careful not to insert your test lead into one of the injector pins. The IDM feeds the injectors 110V and could cause a lot of sparks if it happens to try and actuate the injectors while you're testing, and could worse destroy the IDM, so steer clear of those and make sure you test only the 2 outer pins on each side of the plug.
Connect the ground lead of your voltmeter to a good ground, and insert the positive + test lead into the first glow plug pin.
A good glow plug will read btwn 0.8 - 1.2 ohms a weak glow plug will have much less resistance, and a completely dead one will have unlimited resistance through it because the electrode is internally burned out. Make note of the plugs that are out of range based on the cylinder number, and replace them. The cylinders are numbered 1-3-5-7 on the pass side, front to back, and 2-4-6-8 on the driver's side, front to back.
5b) The test light method - See 5a and substitute voltmeter for test light, if you don't have a voltmeter. Connect the negative end of the test light to a good ground, and insert the test light into the outer 2 terminals on the plug. If the test light illuminates the plug is still working. If the test light does not illuminate, the plug is bad. Make note of the bad ones and replace.
The disadvantage to this method is that it won't tell you if a glow plug is weak, only if it is completely burned up.
*note this does not apply to california emissions equipped vehicles (cali trucks) or the Excursion with 7.3L PSD engine (all years) as they use a controller to actuate the glow plugs instead of a relay. A bad glow plug on these trucks will throw an engine code.
Replacement parts - For the glow plug relay your choices are to buy a stock replacement ($$$), get a GPR-109 from NAPA for less than 30 bucks. This one will work, but some have had issues on them not lasting as long as the stock unit. There is a good option from Stancor, the part number for which I will let someone post. Or you can always find one that's designed similarly and rated for the voltage/amps that the stocker is or better, and use it.
Here is a link for the Stancor unit: http://www.alliedelec.com/Search/Pro...DA8041ECE1 7F
For glow plugs, you want to use only Motorcraft or Bosch plugs. This is very important as the Autolite / Champion cheap brands have a bad reputation for swelling up, burning out prematurely, and breaking off in the head. The motorcraft part number is ZD-11.
The relay is simple to change, disconnect the 2 large terminals, and the smaller ones, unbolt the relay, and install the new one.
The glow plugs are located under the valve covers. Remove the vc's and you will see 4 white wires, with black plug ends connected down beside the injector. Remove the plugs from the gp's, and remove the gp's with a 10mm deep socket.
BMac is offline
post #4 of 9 (permalink) Old 11-21-2008, 09:24 PM
Can't really help you out on this but I had the same issues with my old 99 7.3. Every time it was mild/cold and damp she would not start and I was always getting glow plug codes, after replacing all glow plugs a few times and Ford could still not figure it out it would work fine for a few days after leaving Ford.....Then either and a boat load of it was the only quick solution to my problem and the engine seemed to become more and more dependent on it......After putting up with this recurring issue and dumping lot's of cash troubleshooting, and being let down/SOL for two winters, sold it as is and the new buyer ended up putting in a new engine before solving the problem. Just something to think about if this problem is in for the long haul....Never know you might run into some better mechanics then I did though
post #5 of 9 (permalink) Old 11-21-2008, 09:34 PM
Slim188's Avatar
Send a message via MSN to Slim188
You should talk to shelbyx1, he could probably help you out more then anyone.
2009 Ranger 4x4 Sport
Slim188 is offline
post #6 of 9 (permalink) Old 11-21-2008, 10:23 PM Thread Starter
thanks for the info, the batteries are a year and a half old, do you really think they're bad?
oilman is offline
post #7 of 9 (permalink) Old 11-22-2008, 02:15 AM
BMac's Avatar
how slow is it spinning over cranking? Sometimes batteries are bad right from the store. Just to check have each one load tested
BMac is offline
post #8 of 9 (permalink) Old 11-22-2008, 08:25 PM
glow plug system requires min 10v to work properly bad batteries or high draw starter will cause problems,with the g/p codes you might have a bad v/c harness(known concern)check resistance at drivers v/c connector second term(key off!)to ground should be around .7 to 1.2ohms if high rem v/c check resistance from conn outside to g/p conn if still high check from inside to outside v/c passthrough this will determine if you need v/c gasket or undercover gasket(known concern of connector pins shorting from v/c gask to u/c harness)
post #9 of 9 (permalink) Old 11-23-2008, 07:31 PM Thread Starter
thanks for the suggestions, sorry I couldn't respond yesterday but I was Paged out on some emergency no heat calls. Winter in Canada, people want their furnaces to work, go figure. Thanks again for the tips I'll try them.
GD
oilman is offline
starting issues/ truckguy94 F-150 Pre-1997 Forum 20 05-19-2010 07:32 PM
Tranny Trouble BluByu1986 Driveline and Transmission 9 10-26-2008 09:39 PM
NEED HELP: Tranny trouble corpral diaz Ranger Forum 4 10-26-2008 12:48 AM
trouble codes marsden Truck/SUV Talk 2 05-02-2008 09:22 PM
Cold Weather Starting Ottawaguy F-150 Pre-1997 Forum 9 02-21-2008 11:50 PM
