04 Explorer - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-07-2008, 07:55 PM Thread Starter
04 Explorer
Well my girlfriends explorer is running like crap as normal. At around 90km it starts to shake and sputter once past 95 or so it stops any ideas?
heavyhitter is offline
post #2 of 7 (permalink) Old 12-07-2008, 08:28 PM
Sounds like an out of balance wheel or bad tire, but I'm no expert.
post #3 of 7 (permalink) Old 12-08-2008, 07:43 PM
ive got an 02, there are issues with the explorers ( just like alot of vehicals)
if it does it while driving between the same speeds all the time then its probly a bad tire or out of balance rim. if its the awd model then the sensors can go wacky makeing it seem like the rear tires are slipping so it will engage the front axle can cause a jumpy/shake
post #4 of 7 (permalink) Old 12-11-2008, 03:31 PM Thread Starter
checked wheels and tires for balance or spots and prefectly fine. its not the awd model. no one seems to be able to fix it properly. changed everything fuel lines filter, injectors spark plugs wires
post #5 of 7 (permalink) Old 12-11-2008, 03:49 PM
Adam:was there any codes stored in pcm?that year of explorer had problems with the dpfe sensor freezing up causing egr valve to open incorrectly(the dpfe has 2 hoses going to exhaust manifold)
post #6 of 7 (permalink) Old 12-12-2008, 01:43 PM Thread Starter
i will check tonight thanks
post #7 of 7 (permalink) Old 12-20-2008, 07:00 PM
LaredoRV's Avatar
I had a '03 XLT and never had any trouble... Okay, I just did 12 000kms with it, but I didn't got any trouble
Friends Don't Let Friends Drive Chevy...
LaredoRV is offline
Explorer Plug's? dave151 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 4 10-16-2009 03:43 PM
Explorer OHC... Cowboy Dave Ranger Forum 6 06-15-2008 01:09 AM
92 explorer lift bob_loblaw Wheels and Tires 1 04-27-2008 03:24 AM
Explorer OHC who's done it veskeyw Ranger Forum 4 03-22-2008 05:35 PM
Torque Converter - Explorer harley4 Wheels and Tires 1 11-30-2007 03:17 PM
