Read code 542, Fuel pump secondary circuit failure, PCM to ground. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 10-04-2009, 04:09 PM Thread Starter
mika's Avatar
Send a message via Skype™ to mika
I have 95 Explorer OHV 4.0 6V
This is the code that I stored KOEO – is okay but memory
Code 542, Fuel pump secondary circuit failure, PCM to ground
Car runs generally fine but when I drive in traffic and car speeds up ( rpm's over 2000) and I take off my foot from accelerator pedal sometimes rpm’s drop down to about “ 0 “ and back to 550 / 600 and engine is working properly. But the other time engine is turned off.
After this I check code and there is code 542.
Can anybody help me?
mika is offline
post #2 of 2 (permalink) Old 10-06-2009, 01:31 AM
Mika:this code can come from a poor ground to the fuel pump,also the inertia switch can be part tripped,it can be found on the rh side of the trans tunnel under the carpet,just tap it than push the red button on top and retest for stalling.
Fuel Pump ? kidd F-150 Pre-1997 Forum 5 08-14-2009 04:15 AM
'08 Ranger Engine Failure!! savage rules Ranger Forum 6 04-02-2009 07:49 PM
The proving ground SKRWZ F-150 2009 to 2014 Forum 10 12-08-2008 11:42 PM
fuel pump noname42 F-150 Pre-1997 Forum 5 03-26-2008 09:07 PM
wheel bearing failure canadian redneck Super Duty Forum 6 03-06-2008 01:59 AM
