engine oil? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 01-03-2010, 10:55 PM Thread Starter
engine oil?
In a 2000 7.3l powerstroke, what engine oil should I be using in the winter. Here in the Toronto area it usually hovers between 0 - minus 10 celcius. But it can get colder. My manual says I should use 10W/30. can I use any 10/30 or does it have to be a certain type?
The reason I ask this is I changed my oil last week and put in some Castrol 10W/30, and this week my truck started knocking and ended up stalling on the road. The temp at the time was -15 celcius. The only thing that I've done differently is change the oil to the 10/30.
oilman is offline
post #2 of 8 (permalink) Old 01-03-2010, 11:45 PM
10w30 is recommended for year round use under normal service,as for the knocking and stalling does it idle rough,is it hard starting,what color is the exhaust plume?
post #3 of 8 (permalink) Old 01-03-2010, 11:58 PM
10/30 seems awful light for a diesel motor....? be like running it on water...? no ?
im going to be running 15/40 rotella......5/40 rotella would be a good substitute for winter use
im also the 6.0l not a 7.3l
post #4 of 8 (permalink) Old 01-04-2010, 01:13 AM
You should be using diesel specific oil in your 7.3.
I run 15W40 Rotella dino but may switch to 5W40 Rotella synthetic this winter as I have 320k km's on original injectors.
LOOSEWHEEL is offline
post #5 of 8 (permalink) Old 01-04-2010, 03:16 PM
Black Ice's Avatar
Send a message via MSN to Black Ice
My 2000 f550 with 7.3 I run 1540 in the summer and switch to 030 in the winter.I have 320 thousand km on it.
Black Ice is offline
post #6 of 8 (permalink) Old 01-04-2010, 08:45 PM
esso 0w30 is pimp
post #7 of 8 (permalink) Old 07-16-2010, 09:43 AM
Chevron Delo LT 15/40.
"Dont hit brick walls, They hurt"
RacerM95 is offline
post #8 of 8 (permalink) Old 07-17-2010, 08:03 PM
Rotella 15/40 every time
tranny oil in engine fordfan22 Gas Engines 6 02-06-2010 10:17 AM
What engine oil do you use and When? fordtough.ca Truck/SUV Talk 10 08-15-2008 09:18 PM
Engine Oil JTSF150 Gas Engines 2 09-24-2007 12:54 AM
