No 4wd Low - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 02-28-2010, 02:33 PM Thread Starter
dave151's Avatar
No 4wd Low
I was out in the snow this morning in my explorer and decided to give 4x4 low a try as it's been awhile. I did the old neutral + brake and low and behold no 4x4 low. I didn't hear the usual relay click either. Fuses all look good as well. Am I heading down the road for a new 4x4 module? Would it be covered under powertrain to have this looked at by the dealer?
Any help would be appreciated as I don't want to drain 80 bucks to have the dealer spend 30 seconds with a scanner.
07 Ford Explorer Sporttrac Limited V8 4x4
-Autostart remote starter, Tinted windows, and soon a western bull bar
98 Ford Ranger 3.Slow Stepside
-16" Explorer wheels w/ Dayton AT's, Venstshades, Sunshade, Bugdeflector, and Custom Audio System
dave151 is offline
post #2 of 8 (permalink) Old 02-28-2010, 02:41 PM
I hate these new electronic 4x4 crap..give me a good old lever to pull anytime What's happening when it's turned to 4 low?..does the truck still drive, but just doesn't feel like it's in low? Sorry i can't help more, but the more info the tech guys get, the better..Shelby will chime in i'm sure.
post #3 of 8 (permalink) Old 02-28-2010, 03:38 PM Thread Starter
dave151's Avatar
It doesn't go into 4low at all. No flashing 4low light, no solid 4 low light. I checked connections on the switch and module they are tight.
dave151 is offline
post #4 of 8 (permalink) Old 02-28-2010, 03:42 PM
If you have warranty, I'd call and find out if it's covered.
post #5 of 8 (permalink) Old 03-01-2010, 04:10 PM
does the truck shift into 4x4h ok?did you try shifting it into 4x4l in park with the brake ingauged?these shift motors tend to get weaker as time goes by,also does your brake lights work(the module uses a signal from the brake switch to validate shift)
post #6 of 8 (permalink) Old 03-03-2010, 12:44 PM Thread Starter
dave151's Avatar
My explorer has Auto 4x4 so 4x4 high works fine when shifted into. I'm beginning to think the shift motor is just gummed up from lack of use. My brake switch works as I can hear the solenoid for the console shifter when I push the brake pedal.
dave151 is offline
post #7 of 8 (permalink) Old 02-26-2011, 09:59 AM
Send a message via MSN to stefatc
I would like to know if you got the problem fixed or not. I have the same one here but with the expedition 2006. could let me know what was and what the dealer did and the price too?
stefatc is offline
post #8 of 8 (permalink) Old 03-02-2011, 08:50 PM Thread Starter
dave151's Avatar
I haven't had it looked at yet but like I said I'm almost positive that its the shift motor. For the price of a diagnostic at the dealer I can pretty much pay for the cost of a shift motor. Doesn't the expedition have 2wd mode as well? If you can't shift between 2wd and 4wd hi or low then it may be your shift motor as well.
dave151 is offline
Show us How Low did you go............. fordtough.ca Street Scene 39 03-01-2012 04:12 PM
4x4 Low Problems..... cnelson09 F-150 2004 to 2008 Forum 3 11-27-2009 02:09 PM
low vacuum nnik Gas Engines 10 03-22-2008 12:52 PM
99 body swap from 2wd to 4wd QWKRN-U Ranger Forum 0 12-15-2007 11:30 PM
Problem with 4wd system???? Smokefan Wheels and Tires 17 11-30-2007 09:10 PM
