Heated Seat - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 11-17-2010, 12:17 AM Thread Starter
Heated Seat
Hey all, driving my Excursion today, I noticed that the seat heater for the the driver's seat didn't work. The light on the switch comes on when you press it but no heat. Passenger seat heats up fine. What's the common cause of this, broken heater element? Is this a difficult repair? My wife is after me to fix it before it really gets cold.
Thanks,
George
oilman is offline
post #2 of 3 (permalink) Old 11-17-2010, 08:36 AM
It most likely is the heater element. I changed one on the base part of my 04' F350. It was not that hard.
Basically you:
pull the seat (3 bolts, 1 nut, unplug 2 plugs).
Separate the seat from the back part of the frame
Undo the hog rings on the cover of just the section you want to replace.
Peel back the cover starting at the back/bottom of the seat
Unplug the element and remove (you will likely see where the wires burned on the element)
Slide the new one in and reverse your procedure.
It's not that bad because the cover is already formed to the seat and you don't have to completely remove it.
I think the elements are between 50-100 bucks if I recall.
post #3 of 3 (permalink) Old 11-17-2010, 05:36 PM
You may be able to repair it without having to spend $ on a new element. Are you handy with a soldering iron?
LOOK HERE and HERE
LOOSEWHEEL is offline
Well I got my heated seats! Snowdoogie F-150 2004 to 2008 Forum 7 01-06-2009 01:47 AM
Heated Seats? Swoosh66 F-150 2004 to 2008 Forum 10 11-22-2008 08:36 AM
heated Seat control question??? teckert New Members Introductions 6 10-26-2008 01:21 AM
Which/Who/How? Heated Mirrors Viper238 F-150 2004 to 2008 Forum 6 12-25-2007 06:02 PM
