NEED HELP: Hesitation Under Cruise Or Idle - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 03-01-2011, 10:14 AM Thread Starter
Ok all, I have 2000 Ford Excursion with 205K miles its a V10 6.8L. For the last 2-3 months iv been experiencing hesitation on idle or cruise speeds. For those that have driven a stick, its as if I skipped a gear, or a cylinder or two is not firing. I tried the obvious, changing plugs, fuel filter and using premium gas, no change. The worst part is its intermittent.
When it first started I blamed a local gas station. Went elsewhere and the problem stopped, this was purely coincidence because it started up again a few days later. Hopefully someone has had this headache and remember what or how they fixed it. Fingers crossed.
gixermann is offline
post #2 of 6 (permalink) Old 03-01-2011, 10:21 AM
It might be helpful if you used a OBD scan tool to check for any stored error codes.
post #3 of 6 (permalink) Old 03-01-2011, 03:49 PM
have had some dpfe sensors going bad causing egr valve to open at wrong time,(dpfe is a "box"on the lh side of throttle body with a wire harness and 2 hoses going to it)remove hoses and see if full of moisture/corrosion.
post #4 of 6 (permalink) Old 03-03-2011, 07:58 PM Thread Starter
Thanx
First and foremost let say thanx for taking the time to not only read my post but respond.
B4000 I tried my scan toll but no codes. I must say that was the first time I was ever dissapointed not to have codes.
Shelbyx1 I thought your suggestion thr fix for sure because id been having issue with my climate controls switching to defrost during throttle. Upon inspection I notice one of the hoses was collapsed. I swapped it out and checked for corrosion and rust. Needless to say no luck and no change.
Today I starded my ex up and this time it eas more consistent. I was able to check coils till I found the culprid...cyc3 Ill be grabbing a coil and plug to see if that does the trick..
So any ideas on my climate control.
post #5 of 6 (permalink) Old 03-04-2011, 03:26 PM
on the line from the engine there should be a check valve to hold vacc in system under accell.(it will be black and white and a little larger in diameter then the hose.
post #6 of 6 (permalink) Old 03-04-2011, 04:20 PM
Check the coil packs, if you have them....mine had a hairline crack that the ODB never caught and the unburnt fuel destroyed my catalytic converters $$$$
CharlieZ is offline
Hesitation and HVAC issue Redstuff F-150 2004 to 2008 Forum 3 05-02-2010 03:14 PM
idle/RPM lonerangerxlt F-150 2004 to 2008 Forum 5 02-16-2010 12:45 AM
Idle Problem countryboy Gas Engines 10 01-20-2010 02:31 AM
NEED HELP: 2006 6.0L Hesitation Brocktoones Super Duty Forum 4 06-13-2009 11:53 PM
NEED HELP: high idle CKM Ranger Forum 8 12-09-2008 12:31 AM
