Max PSI for factory chrome wheels - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 34 (permalink) Old 12-30-2012, 10:58 AM Thread Starter
In the near future I'll be switching out the GY P-metrics for some LT C or E load. Does anyone know with certainty the maximum PSI rating on the factory 18" wheels?
Thx
Norotso is offline
post #2 of 34 (permalink) Old 12-30-2012, 11:42 AM
shouldnt it say on the tire?
post #3 of 34 (permalink) Old 12-30-2012, 12:21 PM Thread Starter
WHEEL not Tire.......
Norotso is offline
post #4 of 34 (permalink) Old 12-30-2012, 12:39 PM
how much air are you putting in that the wheel is gonna have problems before the tire.
post #5 of 34 (permalink) Old 12-30-2012, 12:41 PM
Rims should be able to withstand over 300 psi. Your tire pressure is crucial. Go by the pressure on the door post for factory rims and I'm sure someone will have proper pressure ratings for your size of tire and weight of your truck. Sorry, I misread. Your drivers door post should have the proper pressure. Otherwise consult your owners manual.
post #6 of 34 (permalink) Old 12-30-2012, 12:49 PM
that would be for stock tires. if aftermarket i would imagine look at the tire.
post #7 of 34 (permalink) Old 12-30-2012, 01:16 PM
Am I the only one that's confused here ? Why are you worried about how many psi the wheel can withstand ??
Anything more than recommended tire pressure is a waste of air and time.
post #8 of 34 (permalink) Old 12-30-2012, 01:45 PM
Boss F150's Avatar
What air would you put in now? Winter or spring? Do you need to exchange your air for the new year?
Boss F150 is offline
post #9 of 34 (permalink) Old 12-30-2012, 03:08 PM
I'm running full synthetic factory spec air for both summer and winter. Costs a little extra for both sets, but worth it in the long run.
post #10 of 34 (permalink) Old 12-30-2012, 03:15 PM
Ol Skool's Avatar
I don't go for all that fancy Synthetic stuff. I just talk to the flat tire. All that hot air, causes the tire to swell right up. I could-a saved you some doe Mike!....................LMFAO!!
Ol Skool is offline
Max tow package?? lenny1-2mne F-150 2009 to 2014 Forum 3 10-10-2009 07:39 PM
Ranger Max, anyone? CanadianRanger Ranger Forum 11 03-13-2009 04:29 AM
Offset on factory wheels CanadianRanger Ranger Forum 2 07-07-2008 10:33 PM
Hypertech Max E-con Crashnburn Programmers and Tunes 6 05-28-2008 07:33 AM
