Aftermarket Wheels Advice - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 01-18-2008, 09:19 PM Thread Starter
I like these wheels but don't know what size i would need. Need advise. I am also going to do a 4" lift.
http://www.procomptires.com/series1023.htm
white4by4 is offline
post #2 of 9 (permalink) Old 01-18-2008, 09:22 PM
Smokefan's Avatar
17" with a 33" tire
18" with a 35" tire
2011 Chevrolet Camaro RS2SS
2007 Pontiac Grand Prix GXP
2007 Ford Crown Victoria P71
Smokefan is offline
post #3 of 9 (permalink) Old 01-18-2008, 09:34 PM Thread Starter
What size are your ProComps Tim???
What bolt pattern and backspacing do i need???
Why a smaller tire with a smaller rim???
post #4 of 9 (permalink) Old 01-18-2008, 09:37 PM
what rim and tire size do you want to run so we can help you better
post #5 of 9 (permalink) Old 01-18-2008, 09:41 PM Thread Starter
I'll be doing a Rancho 4" lift and don't know what tire/rim combo would look best. Either a 17 or 18 rim.
This is the look i'm after.
post #6 of 9 (permalink) Old 01-18-2008, 09:57 PM
Smokefan's Avatar
I'm running a 17" with 33" tire, the bigger tire would just give you more clearance with the bigger wheel.
Smokefan is offline
post #7 of 9 (permalink) Old 01-18-2008, 11:41 PM
18" rim's and tire's would look great but might be a bit more expensive than a 17" rim package, boath will look great,, I would look at either a 305/70/17 (33.9") on a 17"x9" wheel with 4.5" of back spacing or 325/60/18 (33.3") with a 9.5" rim on a 18"x9.5" wheel that should put you with the look your after also check out wheels here they sell direct
http://www.centerlinewheels.com/index.htm
post #8 of 9 (permalink) Old 01-18-2008, 11:58 PM Thread Starter
Rancho base that suspension lift around an 18x9 rim with a 35x12.5xR18 tire.
post #9 of 9 (permalink) Old 01-19-2008, 12:05 AM
keep in mind a true 35" tire is only 1" taller than a true 33" with the weight of the truck on it and most 35's actually measure 34.5" tall so a 35x12.50 or equivalent will work also
keep in mind the taller the tire the more gear your going to loose, so that could be fixed with a gear swap or a programmer to get some power back
exhaust advice arboc Intake, Exhaust 2 06-27-2008 10:05 PM
Aftermarket Tach install notmuchmud F-150 1997 to 2003 /04 Heritage Forum 13 04-06-2008 03:28 PM
aftermarket LayinHp Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 1 03-08-2008 05:35 PM
