Do you need a programmer to change tire sizes??? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 09-06-2014, 08:40 PM Thread Starter
Not sure of the answer to this for new cars. I know on older stuff like my new truck you can use a programmer to change the tire size in the computer but is that still the cae with today's new cars.
Reason I ask is that we are getting a 2014 Taurus in the family and it comes with 20's. I was wondering if I got 18's for the winter if I would have to reprogram the car for the 18s of if today's cars are smart enough to detect the change and compensate for the difference without me having to do anything.
post #2 of 15 (permalink) Old 09-06-2014, 09:40 PM
The wheel size (18" or 20") doesn't matter so much as the circumference or rolling diameter of the tire.
You need to change the height of the sidewall to make sure the rolling diameter is the same, otherwise the computer will not be happy.
When I had my FX4's, I was running 18's, but there was a better selection of snow tires in the 17" category that were actually cheaper.
The XL models come with 17's, same brakes, so they fit fine on the FX4, and I just went with a tire size that gave the same rolling diameter.
You can actually find on-line calculators that will do the number crunching for you and tell you how close the two sizes are, how far off your speedo will read, and what size tires to use to work with the Taurus.
Incidentally, check the lower end of the Taurus models, I ordered plain jane , black steel wheels off the XL from the dealership, and they were pretty reasonably priced.
post #3 of 15 (permalink) Old 09-06-2014, 09:42 PM
As long as the rims fit, and the overall diameter is the same
(offsetting the original rim size with rubber) both 28" diameter, it won't matter.
no need to get the computer re-programmed. also the diff/trans ratios won't be out, so the RPM's will maintain the same at the same speeds whether on 20's or 18s.
Also make sure you get tire pressure monitor sensors installed, and will likely need either the reflash tool or have ford re-program the vehicle seasonally when you swap them.
edit:
Mike beat me to it. lol
I use this calculator to determine the sizes.
http://www.tacomaworld.com/forum/tirecalc.php
post #4 of 15 (permalink) Old 09-06-2014, 09:47 PM
Yah, but I forgot about the TPMS sensors Travis, thanks for filling in the gaps with the link , that's exactly what I was talking about.
Sensors were pretty reasonable from the dealer as well, just have to make sure they re-introduce whatever set your putting on to the computer each time you swap them out.
post #5 of 15 (permalink) Old 09-07-2014, 08:10 AM
SE - P235/60R17
SEL - 235/55R18 or 245/45R20 (depends on the package)
SHO - 255/45R19 or 245/45R20 (depends on the package)
Compare the 17's to the 20's with the link Travis posted and it shows they're pretty close, with no adjustments to the computer required.
post #6 of 15 (permalink) Old 09-07-2014, 12:21 PM Thread Starter
Cool guys thanks for the link. We may skip the TPMS though just for $ sake. The winter tires we have on Kim's Grand Prix never had the TPMS, the only bad thing about that was you had to clear the message off the screen every time you started the car but that only took a second.
post #7 of 15 (permalink) Old 09-07-2014, 06:33 PM
Boss F150's Avatar
I found that the computer must be able to hold at least 8 sensors as I don't have to reprogram each season. They work just fine all year.
Boss F150 is offline
post #8 of 15 (permalink) Old 09-08-2014, 08:20 AM
So I wondered the same. Ford couldn't confirm this. I swapped tires on my '09 truck once and they worked fine.
post #9 of 15 (permalink) Old 09-08-2014, 05:15 PM Thread Starter
Ok so after using Travis' handy dandy tire calculator we have a winner.
235/65r17 Nokian Nordman winter tires. Same tires I have for the truck just a different size.
Now I need to check with my wheel guys for a set of steel rims, $40-60 each range is what I'm looking for.
post #10 of 15 (permalink) Old 09-09-2014, 12:47 AM
You sure a 65?
Rims sizes? xllxll_VIPER_llxllx F-150 1997 to 2003 /04 Heritage Forum 4 01-13-2012 10:34 PM
Tire change Which one? will99 Super Duty Forum 9 06-25-2011 07:57 PM
Canadian Nitto Tire dealer besides Kal Tire? joeyg Wheels and Tires 5 10-05-2010 07:34 PM
NEED HELP: 2008 SD Lariat: Bushwacker flares, tire sizes..... Clem Super Duty Forum 7 07-21-2009 07:46 PM
