Drivers tire sticking out and noise - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 06-21-2015, 11:32 AM Thread Starter
CDM76's Avatar
Two weeks ago I took my truck into dealership for prepaid oil change. They ended up doing tire rotation at same time, apparently it was part of the package.
About a week ago I started to hear a rubbing sound when I hit bumps. Usually on the downward motion.
Last couple of days the noise has been louder and more frequent. It also lasts longer after hitting the bump. It sounds almost like a tire rubbing on mudflaps or something. The is a slight vibration now too .....
When I got home from work today I looked at the front tires and noted the passenger tire essentially flush with the side of truck (normal) but the drivers side tire is about 2-3 cm out from the side of the truck. I am unsure how long its been like this as is first time I thought to look.
I checked the lugs, they appear fine.
I drive about 1500km a week in the truck and hoping its still safe to drive !!!
Any suggestions about what MAY be wrong ?
CDM76 is offline
post #2 of 14 (permalink) Old 06-21-2015, 12:53 PM
Front or rear?
post #3 of 14 (permalink) Old 06-21-2015, 02:29 PM Thread Starter
CDM76's Avatar
Front
CDM76 is offline
post #4 of 14 (permalink) Old 06-21-2015, 06:36 PM
Check front axle nut Craig.
post #5 of 14 (permalink) Old 06-21-2015, 06:48 PM
Ya, I wouldn't be driving like that. Wheel bearing assembly coming apart? Did someone back the nut off by accident? Jack it up and it shouldn't be too hard to figure out.
post #6 of 14 (permalink) Old 06-21-2015, 07:05 PM
Don't drive it until you find the problem. Check the front end out, first.
post #7 of 14 (permalink) Old 06-22-2015, 10:47 AM
I like Fords Too's Avatar
+1 on checking the axle / spindle nut
it could also be a bad ball joint that's slowly comeing apart or the bushings where the control arms attach to the frame
either should be visiablely distorted from the opposite side if bad enough to cause the wheel to hang outta the fender
I like Fords Too is offline
post #8 of 14 (permalink) Old 06-22-2015, 01:46 PM
lube technician probably did the tire rotation, hopefully didn't back off the spindle nut by mistake and then tighten with the impact.
get it in the air and get it checked out, or if it is a warranty truck, you probably have roadside assistance> call them from your favorite Tim Hortons and let them pay to tow it, dealer should supply you with a courtesy vehicle?
don't drive it far!
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #9 of 14 (permalink) Old 07-25-2015, 12:43 AM
Been over a month Craig, what did you find?
post #10 of 14 (permalink) Old 09-16-2015, 12:16 PM
Think I got it figured, wheel fell off and he ran into ditch or he bought a Ram and is now on a different forum.
Canadian Nitto Tire dealer besides Kal Tire? joeyg Wheels and Tires 5 10-05-2010 07:34 PM
steering sticking chris w Truck/SUV Talk 5 07-06-2010 03:54 PM
Sticking/Stuck Fuel Injectors funford F-150 2004 to 2008 Forum 2 01-02-2009 03:51 PM
