1993 F350 dually 4x4 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 08-04-2015, 10:27 PM Thread Starter
Hello people, will 285/75/16s fit on my 93 dually. Or what will I need to make this work.
cariboofordguy is offline
post #2 of 4 (permalink) Old 08-05-2015, 02:14 AM
they will fit on the wheels. won't have room for them without some lift and they will probably rub together on the duals. and will probably rub on the box inner fenders too. 255/85/16s work fine no lift no issues.
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #3 of 4 (permalink) Old 08-05-2015, 10:34 PM Thread Starter
Thanks for the info, I'm already running 255s and needed spacers to push out the wheels from the axle. With the 255s there is slight rubbing. I did get the proper dually diff, I think it's 1.5 or 2 inches wider backing plate to backing plate, I'm assuming that would be wide enough for the inner wheels to fit, then would need spacers to go between the wheels to keep them apart. I've tried googleing some images but only find dodge stuff, I need to see what a real truck would look like!
post #4 of 4 (permalink) Old 08-06-2015, 02:44 AM
255s fit no mods on a dually 4x4 with a dually pickup rear. a dual wheel cab\chassis rear is a lot narrower. wheel face on them is the same as a standard F250 rear.
shortened a 96 F350 cab/chassis 9' from its potatochip truck wheel base and made it into a diesel 2wd shorty, F250 rotors bolted right on the front and F250 wheels bolted right on the rear with a short pickup bed.
[SIGPIC]
1993 F150 4x4 info needed f150phule F-150 Pre-1997 Forum 5 02-17-2011 09:53 PM
99 f350 psd 1 ton dually Mudwrestler New Members Introductions 17 05-17-2009 02:21 PM
2002 f350 7.3 4x4 quad - silly tire, height, and misc questions Loadedagain Super Duty Forum 1 01-06-2009 12:48 AM
