Welcome to FordTough! International used the same bolt pattern. Two options I see spend the money on non-lock-ring rims so modern tires and tire shops can be utilized or change the hubs to 8 bolt pattern, 6.5 inch bolt circle. Then you have a wide variety of tire options.
