Basic Tire And Rim Questions - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 05-24-2008, 06:22 PM Thread Starter
Cooker's Avatar
Possibly looking into buying a new set of rims/tires. A few questions I have are: What are the benefits of bigger rims (Currently 16"), also benefits of bigger/smaller tire aspect ratio. Stock are 255/70 SR 16.
Cooker is offline
post #2 of 10 (permalink) Old 05-24-2008, 07:49 PM
Mostly about looks, but bigger rims can accommodate allot bigger tires and bigger brakes
All depends on brakes and gears and clearance you have, but I had 265/70/R16 at first on my truck, and I now have 35" tires on 17" rims, I notice a difference when accelerating or stopping but the stopping power is still good and my Edge tuner makes up for stock gears, 6" lift helps clear the tires.
For a stock Ranger I would probably go 16-17" rims on 31-33" tires I think you would be safe, but there is always offset and backspacing to consider, most dealer's know what will fit or not
post #3 of 10 (permalink) Old 05-24-2008, 09:14 PM
Spinal's Avatar
Send a message via AIM to Spinal Send a message via MSN to Spinal
tire size all depends on what you want to do with it.
for my car the stock size is 195/60R15. if you don't know what the numbers mean i'll break it down for you its very simple.
195 = the width of the tire in millimeters, so 195mm.
60 = the percentage of the width, for the height of the tire. so 60% of 195 is 117, so the tire is 117mm high.
and lastly 15 is the rim size.
the middle number is probably the most crucial for handling and ride. soon im changing my tires to 215/45R17. so its going to be a lower profile tire (height) with a fairly large width, this will improve traction and handling a lot. but since its overall bigger, gas mileage and ride will decrease slightly. the middle number more or less determines how comfortable the ride is, also how the tire will handle in cornering.
my dads 2002 F-150 runs a 275/60R17 which is basically just big overall lol, rides nice and has lots of traction.
Spinal is offline
post #4 of 10 (permalink) Old 05-24-2008, 10:04 PM
Smokefan's Avatar
Bigger rims can also lower your fuel economy, nothing worse than seeing a guy get exhaust/intake/tune than throwing 20s on. Bu-bye any HP gains.
2011 Chevrolet Camaro RS2SS
2007 Pontiac Grand Prix GXP
2007 Ford Crown Victoria P71
Smokefan is offline
post #5 of 10 (permalink) Old 05-25-2008, 12:42 AM
Spinal's Avatar
very true, you want a rim that has most of the rotating mass in the center. however you can also get lightweight rims. the 17's that im getting are only 12 pounds, 3lbs lighter than my current stock 15s. they just cost more...however not totally outrageous, about 200 each
Spinal is offline
post #6 of 10 (permalink) Old 05-25-2008, 03:08 AM Thread Starter
Cooker's Avatar
Thanks for the info guys
Cooker is offline
post #7 of 10 (permalink) Old 05-25-2008, 08:01 PM
mitchbtu's Avatar
Dont forget that when you change the outer circumference the distance the tire moves in a single rotation changes and that in turn changes the speedo, and odometer...
mitchbtu is offline
post #8 of 10 (permalink) Old 05-26-2008, 01:20 AM
But as long as the truck is 99+ then you can recalibrate the speedo with a programmer or the dealership can do it. If its pre 99 you have to physically replace the VSS gear under the truck.
post #9 of 10 (permalink) Old 05-27-2008, 10:34 AM
mitchbtu's Avatar
Hmm didnt know that, thanks
mitchbtu is offline
post #10 of 10 (permalink) Old 06-19-2008, 11:40 PM
2insane's Avatar
you think ford can calibrate speedo for a 54" tall tire ???
GO DONOHOE RACING OR GO HOOOOOOOOMMMMMEEEYYY
2insane is offline
Rim Care CanadianRanger Truck/SUV Talk 12 01-04-2009 01:52 PM
Best All Season Tires for a 17" rim? JimRimmer Truck/SUV Talk 4 08-09-2008 07:06 PM
rim width Frumpy Wheels and Tires 10 03-28-2008 09:55 PM
Rim Choice??? white4by4 Wheels and Tires 14 02-17-2008 11:13 AM
