How to correct the tire size in the computer - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 09-02-2008, 10:20 AM Thread Starter
Bruicer's Avatar
Exclamation How to correct the tire size in the computer
What do I have to do to change the tire size in the computer to get my speedo to the right speed as I went from 275/60/17 to a tire 265/70/17 the tire guy told me that the speed wont be out much but when i checked a tire calculator it says its out about 5.1 km is there a way to fix it thanks
Bruicer is offline
post #2 of 4 (permalink) Old 09-02-2008, 03:30 PM
2 ways you can change this
One get the dealer to do this for you or Buy a programmer and you can change it yourself
Either way this will cost you some money
post #3 of 4 (permalink) Old 09-02-2008, 03:59 PM
truckpilot's Avatar
Programmer would probably be better as it comes with the capability to increase your fuel mileage - your dealer doesn't!
truckpilot is offline
post #4 of 4 (permalink) Old 09-02-2008, 05:48 PM
98 and older models use a speedo gear you cant correct tire size with a programmer like on 99+ models the speedo gear must be changed , easy fix.
use this link http://www.bgsoflex.com/speedo1.html
put in your gear ratio you have, tire size, 265/70/17 = 31.7
and Drive or Driven Gear teeth put in 8 for that and you should be bang on
post back what you come up with and I can find the Ford part # you need to order from the dealer
NEED HELP: Tire size. skeg100 Wheels and Tires 3 11-06-2008 06:47 PM
Tire Size Question dranged Ranger Forum 10 08-08-2008 03:06 AM
