Will These Fit - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 11-15-2008, 09:52 AM Thread Starter
Will These Fit
Looking at puting Toyo At 305 55 20 on my factory rims. Will they fit without any problems. 09 F150 4x4 SC KR will be puting on a leveling kit Icon or Bilstein. Thanks
duckdog is offline
post #2 of 4 (permalink) Old 11-15-2008, 12:11 PM
these are about a 33.2" tire and should fit easily with the leveling kit.
post #3 of 4 (permalink) Old 11-15-2008, 07:10 PM
what size was oem 275/55r20? you may want to check lock to lock on front to make sure no interference as these are wider and 3/4" taller
post #4 of 4 (permalink) Old 11-15-2008, 07:21 PM
put on the leveling kit and then get the guys to mount up a front tire and check for clearance while turning the wheel. do this before you buy the tires if you can. i did this when i bought my 285-70-17's, to make sure they'de fit. no leveling kit on my old 05. Kal tire mounted one tire and checked for clearance, and all was good so i bought them.
325-65-18 will they fit????? mgmf-150 Wheels and Tires 4 11-12-2008 07:42 PM
