best aluminum rim cleaner - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 05-19-2009, 10:59 AM Thread Starter
Chienlaid's Avatar
I'm looking for a good aluminum rim cleaner. I have spoke rims and it's a pain in the *** to get my fingers in between and scrub.
[IMG][/IMG]
I would love to find a rim cleaner that requires very little scrubbing. I've tried the Eagle1 I believe it is and it was ok.
Chienlaid is offline
post #2 of 5 (permalink) Old 05-19-2009, 02:27 PM
Blue Oval's Avatar
I just switched from Meguiar's All Wheel to Aluminum Wheel for my factory five spokes and it seemed to work very well. I was recommended to switch because I had inquired about maintaining a wheel where the clear is damaged in a couple of locations and the aluminum cleaner is safer on aluminum because it doesn't contain the acid that the all wheel stuff does, therefore it won't damage the unprotected aluminum further.
Unfortunately unless you clean your wheels every couple of days I don't know of too many wheel cleaners that won't require scrubbing - brake dust is pretty tough stuff. If you don't already, look into getting a spoke brush (check Canadian Tire/Walmart) as this will help you get between those spokes.
Depending on how clean you intend to keep them, Meguiars also just came out with a quick detailer product for wheels. It's a mist & wipe like you would use on paint, only for wheels. I've not seen it in Canada yet though.
Blue Oval is offline
post #3 of 5 (permalink) Old 05-19-2009, 04:13 PM
I just bought some never dull to try I have hear ed good things about it
http://www.nevrdull.com/ avalible @ CT http://reviews.canadiantire.ca/9045/...0P/reviews.htm and Flitz is pretty decent stuff as well http://www.flitz.ca/
post #4 of 5 (permalink) Old 05-19-2009, 06:27 PM
dusted4eva's Avatar
Mothers Aluminum Polish and power ball.
Stock 2009 F-350 Lariat 4x4 Off Road 6.8 V10
dusted4eva is offline
post #5 of 5 (permalink) Old 05-20-2009, 12:29 AM
Stainless's Avatar
I wouldnt use a alum wheel cleaner on your wheels unless its intended for clear coated wheels, otherwise it will turn the clear yellow. Be careful it happened to me years ago. I have a old car wash mit I use for my wheels, it is a pita, but you wont do any damage to your wheels.
Stainless is offline
Rim poll Rustycan Wheels and Tires 18 01-02-2012 05:46 PM
Rim Question dranged Ranger Forum 18 01-22-2009 06:02 PM
Best Place for Aluminum Tool Boxes Steve Ranger Forum 5 06-09-2008 08:56 PM
Rim Choice??? white4by4 Wheels and Tires 14 02-17-2008 11:13 AM
