Reverse Light Solutions? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
Exterior Lighting, Body work, Trim, and Exterior Accessories,
post #1 of 11 (permalink) Old 10-05-2011, 11:00 AM Thread Starter
RedThunder's Avatar
Has anyone noticed how crappy the reverse lights are on the newer F150's? I mean they really really suck...you almost wouldn't even know they were on most of the time.
I've thought about hooking up auxiliary lights, but I was hoping there might be a cheaper and easy solution. My latest thinking is maybe replace the stock bulbs with some LED's from something like superbrightleds.com?
http://www.superbrightleds.com/cgi-b...%2F921-x12.htm
RedThunder is offline
post #2 of 11 (permalink) Old 10-17-2011, 08:47 AM Thread Starter
RedThunder's Avatar
Nobody have any comments?
post #3 of 11 (permalink) Old 10-17-2011, 10:26 AM
Just from an appearance standard I would try to find a brighter bulb or else try to hide the auxiliary lights very well. I don't know what the case is on the 09+ trucks but the reverse lights are very bright on my 05'. I know from trolling several forums installing some extra backup lights isn't hard.
post #4 of 11 (permalink) Old 10-17-2011, 12:34 PM
Never really noticed or gave it much thought to be honest, but what the hell, a swap out to an LED might be worth a shot.
Definitely a cheaper/easier alternative to mounting and wiring a new set of lights on the back bumper.
post #5 of 11 (permalink) Old 10-18-2011, 08:20 PM
LEDs are much brighter. I installed them after tinting the glass on my Ranger.
Besides, the stock bulbs looked yellow with my Recon light bar.
post #6 of 11 (permalink) Old 10-19-2011, 12:38 PM Thread Starter
RedThunder's Avatar
LED's it is...once I get a chance to try them I'll post something back.
post #7 of 11 (permalink) Old 10-19-2011, 07:06 PM
What is the bulb #?
I have an SD and don't know the 150 bulb #'s.
LOOSEWHEEL is offline
post #8 of 11 (permalink) Old 12-06-2011, 03:16 PM
Originally Posted by LOOSEWHEEL View Post
What is the bulb #?
Revers light is most likely a 3156.
Here is a link to find all the bulb numbers for most vehicles.
http://www.sylvania.com/ConsumerProd...lacementGuide/
lthlwpn is offline
post #9 of 11 (permalink) Old 12-06-2011, 09:46 PM
I have noticed the reverse bulbs suck, and anyone that tinted there side windows would even notice it more, I had a set of 55 watt off road fogs mounted under my bumper and tapped into the reverse wire, made a huge difference in lighting but members on here said it looked like crap so I took them off, any aotu parts store should be able to get the l.e.d bulb you need.
post #10 of 11 (permalink) Old 12-12-2011, 06:39 PM
I asked about the bulb type on the F150 because my SD has a 921/168/T10 bulb. I use a CREE 7w LED bulb in the T10 style....direct replacement. If you search on eBay for CREE + your bulb number, you should get a bunch of results. The CREE bulbs are stupid bright.
2004 FX4 lost reverse 1stf150 Driveline and Transmission 0 06-21-2011 06:32 PM
2010 reverse systems aspinape F-150 2009 to 2014 Forum 1 09-14-2009 12:36 AM
Reverse Sensor going off for nothing RJohn357 F-150 2004 to 2008 Forum 10 01-27-2009 08:31 PM
08 Reverse Camera? 04STXHERITAGE F-150 2004 to 2008 Forum 15 12-22-2008 06:49 PM
