IPhone Bluetooth problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 07-30-2012, 05:04 PM Thread Starter
My first post after purchasing a 2012 SCREW Lariat. My iPhone will not carry a call through the truck, it will function for a few seconds and then will drop off line, followed by reconnection and so on. Has anyone else had this problem and if so is there a fix? I'll be bringing it to the dealer soon to query them but thought I might be able to get a heads up through your knowledge base.
taws is offline
post #2 of 8 (permalink) Old 07-30-2012, 06:57 PM
Welcome to fordtough.ca, and congrats on the '12 Lariat.
No real answer for you, but an observation....
With the SYNC system in Ford's being developed and owned by Microsoft, I don't think they'll be going out of thier way to make Apple products work 100% flawlessly.
post #3 of 8 (permalink) Old 07-31-2012, 02:30 AM Thread Starter
I agree that some brand competition exists, but one should assume that Ford would not want to upset a fairly large segment of the smartphone population!
Thanks for the welcome and the truck is amazing other than this one exception.
taws is offline
post #4 of 8 (permalink) Old 07-31-2012, 05:55 PM
My GF's iPhone 3g does the same thing. She doesn't have a Ford. The iPhone seems to want to constantly change it's bluetooth key or pin for negotiating with other things. I got her's to work by locking down the bluetooth access key or pin.
post #5 of 8 (permalink) Old 07-31-2012, 08:33 PM
Cooker's Avatar
Setup an account at sync my ride, then install the update to a flash stick and update your sync, I did it and my iPhone works great now!!!
Cooker is offline
post #6 of 8 (permalink) Old 07-31-2012, 09:56 PM
My sync module died month or do ago. Wouldn't connect to my iPhone 4s. Nor even go into the media or aux setting
post #7 of 8 (permalink) Old 11-13-2012, 01:54 AM Thread Starter
Had the sync unit replaced under warranty after some trouble shooting- now works like a charm!!
taws is offline
post #8 of 8 (permalink) Old 11-13-2012, 09:26 PM
BAM!
NEED HELP: Streaming Bluetooth?? SCrew Lariat F-150 2004 to 2008 Forum 3 11-19-2010 09:01 AM
Aftermarket Nav & Bluetooth Blue Oval Audio and Electronics 9 04-21-2010 07:31 PM
Bluetooth RR Mirror ?? smokum Audio and Electronics 2 01-13-2010 10:50 AM
Bluetooth Question Blue Oval Audio and Electronics 1 01-09-2010 09:46 PM
