NEED HELP: remote control 98 f150 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 17 (permalink) Old 02-13-2013, 03:50 AM Thread Starter
volvering's Avatar
Hello to all,
During the purchase of the truck I had no remote control supplied, I thus wonder if there was originally.
Know you a means to know it ?
What do I have to pay attention if I order it on eBay or others seller ?
thank's for help.
volvering is offline
post #2 of 17 (permalink) Old 02-13-2013, 02:57 PM
I like Fords Too's Avatar
I bought a pair of remotes for my truck off e bay about 1 month ago
they came with the instructions to program them to match the truck's alarm
however I had no luck with the programing , granted it was really cold and dark so I only tryed quickly a couple of times
instead I just pryed them open like I was going to swap the batterys - and changed the circut boards inside them - now they work
you have to be carefull to read the adds right
some will be a complete remote - some will be only a replacement shell with no parts inside to make them work
I think your truck would also use the 3 button remote like mine - lock,unlock & panic
if you check enough e bay adds you will find they come in black , red or blue
I like Fords Too is offline
post #3 of 17 (permalink) Old 02-14-2013, 04:27 AM Thread Starter
volvering's Avatar
ok, you change the circuit inside remote control, i think you have others remote before purchase?
I see the problem with replacement shell and be very carefull..but on ebay every remote i see don't ship with the instruction for programing..
post #4 of 17 (permalink) Old 02-14-2013, 07:47 AM
You get the remotes and We or i will post the instructions.
I'm mobile right now, so little more challenging.
post #5 of 17 (permalink) Old 02-14-2013, 02:26 PM
We all know you're challenged Travis
post #6 of 17 (permalink) Old 02-14-2013, 03:33 PM
Programming those remotes are simple even Jim could do it
post #7 of 17 (permalink) Old 02-14-2013, 04:34 PM
More then one way. Lol
Programming directions
To program the transmitters yourself:
Insert a key in the ignition and turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position.
The doors will lock/unlock to confirm that programming mode has been entered.
Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
When you have completed programming the remote transmitters, turn th ignition to 3(Off) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
post #8 of 17 (permalink) Old 02-15-2013, 01:54 AM Thread Starter
volvering's Avatar
great i go to purchase two remote transmitter,,, thank's all...
post #9 of 17 (permalink) Old 03-25-2013, 01:01 PM Thread Starter
volvering's Avatar
hello i have purchased the remote and test programming but not great for me.
it's not possible for me to enter to the programming mode, i turn the key 8 times and nothing work?
i just insert the key (Pos 3?) and turn to the position just before start engine (pos 4) and that doesn't work for me.
I made the test correctly or not ?
post #10 of 17 (permalink) Old 03-25-2013, 01:11 PM
Turn the key off and on to acc 7-8 times not to the run position this will get the for locks jumping up and down when. This happens hold the lock button on your remote and they should work after that
remote starters arboc Audio and Electronics 9 06-27-2010 07:06 PM
09' f150 traction control light zeke1030 Driveline and Transmission 3 07-07-2009 05:52 PM
Remote starter brauner_1 Audio and Electronics 1 12-16-2008 03:35 PM
Remote starter, who has one? fordtough.ca Truck/SUV Talk 12 09-27-2008 02:20 PM
