Audio Wiring - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 10-26-2008, 01:11 PM Thread Starter
Justin1635's Avatar
Audio Wiring
does anyone else upgraded audio on the 07/08 f150s?? if so where did you run your power wires to the batt? right now i have it running under the cab through an access hole in the floor. i couldnt find any on the firewall to run through, and i dont wanna drill my own, any ideas?
"The Dark Knight"
Justin1635 is offline
post #2 of 3 (permalink) Old 10-26-2008, 01:29 PM
There is a rubber plug in the firewall just above steering column
Are you running power to the sub, or just new head unit?
post #3 of 3 (permalink) Old 10-26-2008, 07:06 PM
Yes look for a rubber grommet in the fire wall if you look in the engine compartment on the driver side fire wall it's easier to see, then you know how low too look for it inside. Did that for MartyF150XTR last year on his 07. I think you have to pull the carpet ever so slightly on the top left corner and it right behind there. It's only about 1-1 1/2 inches big.
Also did it on my 06 F250, same place
NEED HELP: With 2007 FX2 audio upgrades? 04STXHERITAGE Audio and Electronics 6 11-13-2008 02:54 AM
Anybody on wiring ? Umaxman Audio and Electronics 2 05-25-2008 09:44 PM
battery JB wiring removal?? lightning25 Audio and Electronics 1 08-28-2007 09:55 PM
