94 Explorer Audio Problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 05-31-2009, 01:33 PM Thread Starter
Ive just put an Alpine CD player into my Explorer. Used the aftermarket install harness, Only plays on the Left channel, thought it could have been the Factory amp (Premium Sound, NOT JBL) so I went and picked up the bypass harness for that, still have the same problem, any ideas other than just hard wiring the the Speakers in ?
PS Its not the deck, I tried the deck out of the truck and it works fine
"Dont hit brick walls, They hurt"
RacerM95 is offline
post #2 of 2 (permalink) Old 05-31-2009, 03:37 PM
if you are bypassing the amp anyways (which is what I think I am reading), I would run new heavier speaker cable to the speakers. The hardest part is getting the wire through the door boots but thats not too bad once you get onto it. Then at least if you decide to add an amp later, you already have the wiring run. If you run two sets at the same time, you can later add componet speakers if you want and the X-overs will be inside the vehicle instead of in the doors. The doors are not a good place for them anyways.
04 Explorer heavyhitter Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 6 12-20-2008 06:00 PM
NEED HELP: With 2007 FX2 audio upgrades? 04STXHERITAGE Audio and Electronics 6 11-13-2008 01:54 AM
92 explorer lift bob_loblaw Wheels and Tires 1 04-27-2008 02:24 AM
