Project: Preview - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 18 (permalink) Old 02-21-2010, 08:23 PM Thread Starter
Project: Preview
post #2 of 18 (permalink) Old 02-21-2010, 08:43 PM
I always wanted one of those.......I think
clamhunter is offline
post #3 of 18 (permalink) Old 02-21-2010, 10:13 PM Thread Starter
post #4 of 18 (permalink) Old 02-21-2010, 10:13 PM Thread Starter
post #5 of 18 (permalink) Old 02-22-2010, 09:09 PM Thread Starter
Took me about 3 hours of design.
then couple hours to get it on the wood and put it together.
I picked up a couple Pioneer shallow mount subs for cheap. possibly blown, but they both pop. so have to see how they turn out.
Pioneer Shallow Mount 12" Sub - TS-SW301
the box has about 0.78 cu. ft of air space minus the displacement of the sub.. It's a very shallow box, but if you've seen under the seat of any of the trucks you'll see their isn't much room.
As you can see the box fits like a glove under there, with a small amount of play. Just enough to put on some carpet an finish her off.
Hope it sounds as good as it looks.
I know of another member that wants one of his own. .
post #6 of 18 (permalink) Old 02-22-2010, 09:13 PM
nice setup
and ive got the same table saw lol
post #7 of 18 (permalink) Old 02-23-2010, 06:11 AM
Blue Oval's Avatar
Looks like a perfect fit; here's hoping it sounds great!
Blue Oval is offline
post #8 of 18 (permalink) Old 02-23-2010, 07:07 AM
That sub needs .5-1.0 cube of air so you should sqeak in over the minumum.
Do you still have a little air space behind the magnet? I don't imagine it needs alot, the sub is under 4" deep, quite amazing actually.
What amp are you going to power it with?
Based on the positioning in the picture, you are down firing it, right?
I'll be interested to hear your impression of it!
post #9 of 18 (permalink) Old 02-23-2010, 09:26 PM Thread Starter
I haven;t bought an amp for it yet.
I'm borrowing a Rockford P300-1 to test it. It's a mono that rated at [email protected] but it puts out [email protected] 4ohms. so it will work for testing purposes.
Yes downfiring.
well only the edge gets close to the inside of the box and there is about 1/4" at the closest point. So it will be fine.
I was going to go ported, but couldn't get enough air space. aswell the sub's fs and QAS make the sub work better for sealed subs anyways.
ps.
I did my own air space calculation. as I was using some on-line calculators to give me a referenc point. it actually works out to be .803cu ft.
so It's got plently of space. as this sub doesn't take up very much space in comparsion to a standard sub. (as per the point of the sub)
I think I'll get away with about .65 cu ft.
post #10 of 18 (permalink) Old 02-23-2010, 10:00 PM Thread Starter
Thanks!
So, whats your next project? fordtough.ca Projects and Build-Ups 69 03-18-2011 06:23 AM
my next project Henry Ford F-150 Pre-1997 Forum 0 09-26-2009 08:59 AM
Slim's Project MFR Slim Projects and Build-Ups 10 05-17-2009 11:15 AM
Next Project, U joint replacement jos1959 F-150 1997 to 2003 /04 Heritage Forum 13 08-30-2008 01:06 AM
new project martyF150XTR F-150 Pre-1997 Forum 10 08-16-2008 08:15 PM
