1979 Bronco Trail rig - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
Projects and Build-Ups Post about your current project, latest mods, and build-up.
post #1 of 26 (permalink) Old 08-27-2008, 01:23 PM Thread Starter
1979 Ford Bronco 400ci V8, C6 auto, np205, 9" rear spooled, hp D44 front welded, 3.55 gears.
I got this Bronco for a sweet deal a couple years ago and did the drivers side head last summer only to have the other head gasket go one week later. At least I am hoping that it's only a gasket, the head I replaced ended up being cracked.
To do list:
-Assemble engine
-change trans fluid/filter
-rebuild front driveshaft
-install spool in rear
-mount super swampers
-mount winch
-finish painting body
-replace rear pinion seal
-install new hubs
post #2 of 26 (permalink) Old 08-27-2008, 07:26 PM
that's a nice diamond in the rough. go for the 460!!! never heard of a 9" front axel, if you make it work post some pics
post #3 of 26 (permalink) Old 08-27-2008, 09:42 PM Thread Starter
Thanks. Currie sells the parts but I am hoping for a junkyard build.
post #4 of 26 (permalink) Old 08-27-2008, 09:58 PM
Oh My Hog's Avatar
What are you posting here for? Get to work.
Nice project!
Oh My Hog is offline
post #5 of 26 (permalink) Old 08-28-2008, 12:30 AM Thread Starter
Thanks Paul, I would be working on it but the budget needs to come around first.
post #6 of 26 (permalink) Old 11-05-2008, 08:13 PM Thread Starter
Did a little bit of work today.
Before
Before, well during I guess.
Coat#3
Did 4 coats total and now I'll let them dry over night. After pics will be up tomorrow. Oh and one more pic, it's a before pic of the front diff wich I plan to paint as well.
post #7 of 26 (permalink) Old 11-06-2008, 01:08 AM
Sean:if the 400 bottom end is good an old mud racing trick was to put 351c 4bbl heads and 351c solid lifter cam in the longer stroke of the 400 made good use of the flow of these heads.(and the eng revs better than a big block)
post #8 of 26 (permalink) Old 11-06-2008, 01:10 AM
ps:it looks from pics that you have a dana 50 or 60 front diff,good stout diff
post #9 of 26 (permalink) Old 11-06-2008, 01:52 PM Thread Starter
I'll definetly keep that in mind as I am about to have the second head rebuilt. Should I just look for a set of 351c heads instead of rebuilding this one? I am new to all this stuff so I appreciate the opinions. And I am on a TIGHT budget. I drove it for a week after I did the first head and it ran awsome so I am assuming that the bottom end is good.
I was told when I bought the diff that it is a 44. Looks the same as the one under the Bronco now. How could I tell the difference?
post #10 of 26 (permalink) Old 11-06-2008, 08:54 PM Thread Starter
Here are the after pics
Need help with trail cleanup Fordwheeler Off Road 9 09-10-2008 06:54 PM
My new wheeling rig Frumpy Truck/SUV Talk 5 08-29-2008 11:55 AM
On the trail with cooker RuggedRanger15 British Columbia 15 07-22-2008 11:03 AM
Diesel Bronco blaze42069 Projects and Build-Ups 1 12-05-2007 10:57 AM
