6.7 engine noise - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
Diesel Engines Intake, Exhaust, Tunes, and Mechanical Info
post #1 of 5 (permalink) Old 11-28-2013, 03:32 PM Thread Starter
6.7 engine noise
My 2013 f350 has been sounding louder than normal for a couple days, rattling at an idle. It seems to be lacking a bit of power an now I got an engine light. I'm unable to get in into the dealer till next Friday. Just wondering if anyone else has had this issue.
Kurtf350 is offline
post #2 of 5 (permalink) Old 11-28-2013, 05:02 PM
You are the first that I have seen here with a 6.7L. Not sure if you'll get much response from us. I'm also a member thedieselstop.com...a great site for Ford diesel truck owners. Have a look there, if you haven't already. Good luck.
post #3 of 5 (permalink) Old 11-28-2013, 06:07 PM
6.7 engine noise
Sounds like a piston rod?!?!
What's your previous maintenance like?
Spot on oil changes? Go over? Where do have you got them done?
post #4 of 5 (permalink) Old 11-29-2013, 12:04 PM Thread Starter
I ran the codes got "offset learning min pressure" for injectors 5,7,8. Also got a low fuel pressure code. Filters? Maybe run some conditioner? Anyone with knowledge of this I'd sure like to know more.
Kurtf350 is offline
post #5 of 5 (permalink) Old 11-29-2013, 12:11 PM
I think changing fuel filters would definitely be a logical start. If the newer trucks are anything like my 6.0L, stick with factory filters (oil and fuel). I'd change filters only, then drive it and see what happens. That way you know what change helps.
I could use some help with a noise. Cav F-150 2004 to 2008 Forum 11 04-18-2013 09:29 PM
engine noise Maverick_Brittany F-150 2004 to 2008 Forum 19 01-10-2012 06:10 PM
NEED HELP: Grinding Noise Coruptyed Gas Engines 8 12-06-2008 04:49 PM
Engine noise through speakers? jackhammer Audio and Electronics 3 11-23-2008 05:18 PM
engine noise on start up??? silverfox Gas Engines 14 09-24-2007 11:50 PM
