NEED HELP: Mods & Loss of Fuel Economy - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 03-14-2012, 09:38 PM Thread Starter
I own a 2008 F-250 Supercab 4x4 with the 5.4L engine. I recently installed a Flowmaster single exhaust as well as an Air Raid Cold Air Intake. The truck went from 22L/100km average to 17L/100km with these installed. The truck gained a decent amount of power as well.
I then had the Catalytics emptied on the advice of the local mechanic. I am now at 20L/100km and it seems i have lost a bit of the new power as well. Is this due to a loss of Backpressure, or is there something else going on.
Overall I am happy with the changes but I was really looking to keep the substantial gain in fuel economy. Should I be looking at a tuner now, or will the tuner not give me the fuel millage increase either?
razrsege is offline
post #2 of 15 (permalink) Old 03-14-2012, 10:05 PM
I'm thinking you are probably running bit lean now and tuner should help but lets see who else has an opinion on this.
post #3 of 15 (permalink) Old 03-14-2012, 10:07 PM
Time for a tuner.
post #4 of 15 (permalink) Old 03-14-2012, 10:15 PM
Instead of gutting your cats should have just put some hi flow ones on and get a custom tune
post #5 of 15 (permalink) Old 03-15-2012, 10:16 PM Thread Starter
5.4L Gas Milage questions
Thanks. I did not know about high flow Cats. The local mechanic said he had gutted alot of Cats in Chevs but not that many 5.4L Fords around, all Diesels. Seemed like a good idea as there would be no restrictions.
The truck is running great and now that I have driven for 700km, the milage is definately better than before the upgrades, power is very good as well. Truck used to shift out of overdrive constantly even with a strong headwind. This does not happen anymore, very happy bout that.
Anybody know which is the best Tuner for the 5.4L, and will it hurt my transmission?
razrsege is offline
post #6 of 15 (permalink) Old 03-15-2012, 10:19 PM
Fix the cats. Your screwing up your O2 sensors.
post #7 of 15 (permalink) Old 03-15-2012, 10:52 PM
hihosilver's Avatar
Is there two or four o2 censors on the 5.4? Cuz on my 4.6 I'm not running cats and was told the rear sensors are used just for testing to make sure the cats are working the have no effect on the motor performance at all I even ran with out them for a day
hihosilver is offline
post #8 of 15 (permalink) Old 03-16-2012, 08:45 PM
As for a tuner you can go with a SCT or a Superchip and no it won't hurt your tranny as you can adjust it also.
post #9 of 15 (permalink) Old 03-16-2012, 09:12 PM Thread Starter
So, what will happen if the O2 sensors fail? Freakin mechanic, he should replace the Cats. Thanks Lumberjack, sounds good. I was looking into Superchip.
razrsege is offline
post #10 of 15 (permalink) Old 03-16-2012, 09:17 PM Thread Starter
Hey silver. There are 4 O2 sensors on mine as well. The mechanic said that all that would happen is that my service engine light would come on, which it has. I was hoping that with a Tuner, I could reset the engine light. My engine is running like a top and my milage is still better than before. Don't really know what the long term effects will be, but if there is, the mechanic wil be paying for all of it for sure.
razrsege is offline
Fuel Economy Bandit993 F-150 2009 to 2014 Forum 37 04-04-2012 08:56 PM
5.4 fuel economy buffalo1973 F-150 2004 to 2008 Forum 24 05-02-2011 02:42 PM
Fuel Economy for 6.7 4xford Super Duty Forum 11 12-23-2010 04:36 PM
fuel economy Waborita92 Ranger Forum 3 09-03-2009 08:30 PM
fuel economy improvements??? 1tonne New Members Introductions 10 05-08-2008 04:35 PM
