common oil leaks on 4.6l's? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 03-20-2012, 11:33 AM Thread Starter
hihosilver's Avatar
well i started to install my body lift last night and i noticed that the back and side rails of my oil pan are damp with oil it never leaves a spot in the driveway and is never low on oil. its not dripping wet just damp just wondering if anyone else has had any oil leaks with these motors i really hope its not the rear main.
hihosilver is offline
post #2 of 3 (permalink) Old 03-20-2012, 06:46 PM
Probably not rear main seal. Sounds like weeping a bit on sides and pulled back by gravity.
post #3 of 3 (permalink) Old 03-22-2012, 07:18 AM
back of the valve covers have had weeping issues a new gasket has fixed others but most leave it unless it gets real bad
common switch cdnarmyguy F-150 1997 to 2003 /04 Heritage Forum 2 11-30-2011 10:31 AM
injector leaks northernlights Diesel Engines 5 11-12-2009 12:30 AM
What oil do you use? Smokefan Gas Engines 23 02-18-2008 07:53 PM
