Coil packs - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 03-25-2012, 02:06 PM Thread Starter
Coil packs
Anyone ever do a distributor to coil pack conversion using the same fuel injection computer? Getting a bit tired of having to change the distributor cap and rotor. Looking to hear about any pitfalls that I may not have thought of.
post #2 of 8 (permalink) Old 03-25-2012, 02:46 PM
You're tired of doing a cheap and easy job????
post #3 of 8 (permalink) Old 03-25-2012, 05:18 PM Thread Starter
Distributor caps and rotors just don't seem to last as long as they used to. I'm changing it in just under a year. Used to get a year and a half to two years out of them under heavier conditions.
post #4 of 8 (permalink) Old 03-25-2012, 05:27 PM
Really? This thread made me realize I haven't changed mine in almost 3yrs
post #5 of 8 (permalink) Old 03-25-2012, 09:22 PM Thread Starter
I changed the coil last year to discover it should have been changed about 10 years ago. I guess 295,000km out of an ignition coil is pretty good. It hadn't failed yet but was getting hard to start. New coil made a huge difference. Better starts, better fuel mileage, and a little more pep.
post #6 of 8 (permalink) Old 03-26-2012, 07:13 PM
What kind of shape is your dist body in? Lots of slop in shaft will take them out quicker.
post #7 of 8 (permalink) Old 03-27-2012, 07:48 PM Thread Starter
The shaft is still reasonably tight. First thing I thought of. Distributor is burning out evenly but just sooner than they used to.
post #8 of 8 (permalink) Old 03-27-2012, 08:20 PM
You probably do but going to suggest putting bit of dielectic grease on tip of rotor. Other than that all I can say is they are not selling as many anymore so cheaper materials so you guys have to replace more often.
2004 F150 Ignition Coil "A" Haley-Special F-150 2004 to 2008 Forum 4 10-14-2010 10:24 AM
Front Coil Springs JTSF150 Suspension 1 06-16-2010 05:13 PM
Found a good deal on V8 Coils packs Rangerdude1987 Truck/SUV Talk 2 05-17-2009 02:04 PM
